Home Forums Printing Discussions HP Printers Hp Designjet 430 advice needed
  • Hp Designjet 430 advice needed
    Posted by Lorraine Clinch on 26 February 2008 at 16:44
    I have just acquired (for a tenner!) one of these printers – funny story, which I’ll save for another time! – which came with no software.
    I don’t know if it works, although it certainly seems to be making the right noises when switched on.
    I seem unable to download any functioning software for it. Looking on the net, it seems that I may have problems getting the downloads, and wondered if anyone is using one of these and could point me in the right direction?
    Also, as there is a total lack of info, can anyone tell me what it prints on to? Is it only paper, or other media too?
    Sorry for all the silly questions, typical really that something like this happens when you have the least time to deal with it! 😕
    Lorraine Clinch replied 17 years, 10 months ago 2 Members · 13 Replies
  • 13 Replies
    26 February 2008 at 16:53
    see if this works
    General
    Device TypeInkjet
    Dimensions (W x D x H)1031 x 231 x 332 mm
    Weight26 kgPrinter
    Output typeMonochrome
    Print speed (b&w)1.5 min/page ppm
    Max resolution (b&w)600 x 600 dpi
    Ink consumablesOne black Cartridge Media Handling
    Media typePlain paper, imaging film
    Max document size (print)23.4 in (A1) x 33.1 in (A1) Expansions / Port(s) Required
    Port(s) / Connector(s) requiredIEEE-1284 compatible, RS-232-C
    Additional info (connections)Information not available Memory / Processor
    Installed memory4 MB
    ProcessorInformation not available
    Additional info (memory)Can be upgraded to 36 MB Software / System Requirements
    Software includedDrivers & Utilities
    Supported operating system(s)Windows 95/98/NT 4.0 Warranty
    26 February 2008 at 16:56
  • Lorraine Clinch
    26 February 2008 at 16:57
    Hi Chris
    Speedy reply!
    Confusing thing is, this has 4-colour cartridges, and a cutter, but I can only find references to monochrome on the net, as you have!
    Anyone any ideas?
    26 February 2008 at 17:02
    look at the serial number plate to see the actual model
  • Lorraine Clinch
    26 February 2008 at 17:31
    Been looking for model no’s, never thought to look under the lid!
    Going now to HP site…
  • Lorraine Clinch
    26 February 2008 at 17:35
    Nope, no good! Comes up with error message.
    26 February 2008 at 17:47
    so what did the serial plate say then Epson 😉
  • Lorraine Clinch
    26 February 2008 at 18:07
    :lol1: Sorry, didn’t know you were asking!
    Model no. C4713A
    Still can’t get anywhere.
    26 February 2008 at 18:56
    this link shows there was a colour upgrade kit available, might explain the confuion
    http://www.laserjet.co.uk/designjet430.htm
  • Lorraine Clinch
    28 February 2008 at 17:11
    Hi Chris, thanks for your research and replies, that last site looks good, I have been busy so unable to contact them, but will try tomorrow.
    Do you have a Designjet?
    I know it prints onto paper, but don’t understand ‘coated’ paper or image film-think that’s what it’s called? Wondered what anyone else uses theirs for?
    28 February 2008 at 22:57
    no i dont have one thank you but use similar before.
    standard plotting paper used for plotting line drawings
    coated paper DYE based for quality printing. some times called photo paper.
    film for screen printing art work may not be dense enough thou.
    there is a SA vinyl called micro porous matt finish only. dont get your hope up.
    those inks are Dye based and will fade quickly and are not water proof but at 600 dpi on to a good paper will make good indoor stuff.
    when buying coated paper it must be either universal or for dye inks. not for pigmented inks,
  • Lorraine Clinch
    29 February 2008 at 14:13
    Thank you Chris for explaining all that, a bit clearer now. I’ll have to put getting it up & running on the back burner for a while now, getting behind with the sign making!
