Home Forums Printing Discussions HP Printers HP Design Jet 70, can it print on vinyl?
  • HP Design Jet 70, can it print on vinyl?
    Posted by Ross Frederick on 4 September 2009 at 20:34
    Hi hope you dont mind me asking .
    Im just using a basic HP DESIGNJET 70 printer.
    1st question can I print on Vinyl and if so can you point me in the direction where I can buy A2 print size vinyl.
    All the best and thanks for any help on this .
    Ross. 😛
    Peter Mindham replied 16 years, 3 months ago 3 Members · 3 Replies
  • Ross Frederick
    5 September 2009 at 21:19
    😛 I guess not
    Cheers all.
    5 September 2009 at 22:01
    Ross, we have a tendency to wait for you to introduce yourself in the hello section before we help new members to this board, that might sound a bit harsh but we try and keep it friendly here.
    those who contribute normally get help from those that have been helped by another, that sort of thing.
    So I will answer your question… self adhesive vinyl can be printed with a solvent printer and a UV printer, with a solvent printer they have heater that relax the surface of the material so it helps the ink fuse to the surface of the media. A UV printer uses ink that doesn’t cure by the air and will lock together with the surface of the media when UV light passes over it.
    The HP 70 appears to be a desktop printer, i have no idea about it’s heaters or the type of ink it uses but you will find that most of the printers that are designed for printing on vinyl can cost between £10K to £50K
  • Peter Mindham
    6 September 2009 at 07:25
    I would doubt it would print on vinyl. Perhaps coated but I think it unlikely.
