quote Alex Pirozek:
Isopropanol is all i use on the PC-600 for cleaning the vinyl down EVERYTIME before printing. Can’t remember the last time i had a ribbon snap.
When i used them I found that Kurtz type of ribbons from germany snapped on me often, I only use original Roland or the other main refill supplier in the UK.
You can reduce the head temp slightly if it’s still giving you problems.
Also check the foam roller (the small roller that puts the ribbon down after the head) as this needs to be in good condition as well.
Alex.
Hi Alex,
Yes, the Kurtz ribbon is not good, I have just tried samples. I need to find the isopropanol over here, as ethanol can only be bought in 10ml quantities because people make booze from it. I didn’t have a problem with static with iron-on material, only vinyl and having read (probably your) other threads reduced head temperature prior to starting work. Only unavoidable problem is that printing is so darned expensive 🙁 Am going to have to look into an ecosolvent at some point but that is big bucks.
Will look for the foam roller – good to know.
Thanks for the advice!
