Home Forums Software Discussions Corel Software how to create a outline around whole object/image?
  • how to create a outline around whole object/image?
    Posted by Paul.Gardner on 19 February 2010 at 08:51
    How is correct way to create a outline around whole object/image, needs to be exact around object as it is for cutting, have tried create boundary, but for some reason i keep getting program not responding, and object is only a simple traced logo (corel x3 win 7) is there another (correct ?) way to do this.
    Thanks Paul
    :police: Mod-Edit
    * Please use "Descriptive Topic Titles" when posting.
    * This posts Title has now been edited.
    Please take a moment to look over our Board Rules.
    Steve McAdie replied 15 years, 10 months ago 7 Members · 10 Replies
  • 10 Replies
  • Terry Bull
    19 February 2010 at 09:26
    in corel is it not the contour command for outlines
    Terry
  • Chris Windebank
    19 February 2010 at 09:28
    can you post the file in the file swapping forum? Sounds like you need to reboot Corel on start up mentioned earlier this week to reset things. create boundary is the easiest method but the other way I use is select the whole group, duplicate, weld all and then create outline
    19 February 2010 at 11:13
    quote Chris Windebank:
    c the other way I use is select the whole group, duplicate, weld all and then create outline
    what him say!
  • Paul.Gardner
    19 February 2010 at 11:56
    I seem to have found solution, the image was made up of many layers, so i cut the background layer pasted to new page & create boundary worked fine, then i just cut & pasted back to original page.
    Thanks for help 😎
    Paul
  • Adam Ross
    5 March 2010 at 12:58
    I would like to remove the white rectangular background from a circular jpg photo is this method suitable for that ?
  • Paul.Gardner
    5 March 2010 at 14:23
    Not sure of the correct method, but i usually remove the background from a photograph with photoshop using the eraser or magic eraser, am sure there is a better way though
  • John Childs
    5 March 2010 at 16:10
    quote Adam Ross:
    I guess it depends on the file.
    In Illustrator we just export the file as a jpeg with a transparent background and that leaves just the image.
    Do it all the time with jpegs lifted from customer’s websites when doing rough van visuals.
  • Adam Ross
    5 March 2010 at 16:17
    Hi john
    For some reason in corel the box tick box for exporting with a transparent background in not available
  • John Childs
    5 March 2010 at 16:29
    quote Adam Ross:
    Oh dear.
    I can’t help then – you need a Corel guru.
    I’m sure that one will be along shortly. 😀
  • Steve McAdie
    5 March 2010 at 16:48
    I don’t think you can do transparent background as jpeg would need to be removed then saved as something else like a gif.
