Activity Feed › Forums › Sign Making Discussions › Off Topic Chat › how old is she now
how old is she now
Posted by Derek Heron on July 5, 2010 at 6:05 ammorning all
passed this sign for a couple of years now without looking too much.
had a closer look yesterday 😮 ding dong
i wonder how she is nowDerek
Peter Normington replied 13 years, 10 months ago 8 Members · 12 Replies -
Hi Derek,
About 117 years old:
The bridge was built in 1893 for the Newburn Bridge Company by Head Wrightson of Thornaby-on-Tees and designed by Sandeman and Moncrieff of Newcastle. It is a steel lattice-girder structure and there are four spans, and it has very deep foundations of over 70 feet below high water. Originally a toll bridge, it was bought by Northumberland in 1947. The toll house was at the north east end but has been demolished. Water, gas and telephone cables are also carried over the bridge. In 1960 a weight restriction of 9 tons was placed on the bridge but when it was narrowed to single line traffic this was raised to 10 tons.
Cracking bird on the sign though! :lol1:
Hi john
I have to ask, How did you know all that?
Did you google it or do you just like bridges.
cheers Mike 😮 -
According to bridge Historian John Gregson.
Bowstring bridges are one of the rarest types of truss bridges, and most date in the 1870s. They fell out of favor due to the limited weight they could support. Any bowstring truss bridge that survives today is a miracle. Truss bridges are always intricate structures, but bowstring trusses are even more so. There [are] lattice, v-lacing, and members all over. This large amount of complexity is balanced by the simple, graceful appearance of the arched top chord. The result is a bridge with incomparable beauty and appeal. Among the rarest and oldest bridges in Canada is this breathtaking iron bowstring truss. Keystone Columns form the top chord. A sidewalk on the south side appears to be original. The bridge has undergone extensive repairs and modifications. Most notably, the top chord has had plates of steel welded to the top of the column. Numerous rods and bars have been welded onto many of the vertical and diagonal members as well. A couple of added bars of steel run lengthwise through the middle of the truss. These modifications have affected the historic integrity of the bridge, but have no doubt helped keep it standing over 130 years. The original lattice guardrails remain on the sidewalk, albeit with a metal pole welded above them. [2]
The deck surface (see illus. gallery below) is presently of renewable planking: a double file of approximately one-thousand, five hundred eight-foot two-by-fours each, on edge, upon a framework of nine longitudinally laid stringers of one-foot iron I-beams, topped with bolted-on wooden cladding, whose ends rest on the two abutments. Attached beneath these are fifteen transverse floor-beams, from which vertical lattice pillars, under tension, translate the live thrusts of traffic to the bowed upper chord, which transfers this back as tension along the bottom-chord "string" of the bow. This bottom chord consists of two sets of four 10 cm x 3 cm wrought-iron eyebars, running along, outside, both sides of the deck. Although originally two-lane, due to the weight and frequency of modern traffic, the Blackfriars is at present two-way but single-lane. Because of damage to the wooden deck surface and to the iron structure, there is recurrent consideration of closing it to four-wheeled vehicles.
ca 1878: BSB from southeast; Petersville left, original Carling brewery right
2007: BSB from southeast; showing west bank modern dike, Oxford Street bridge upstream, north – photo PM[edit] Historical, natural and cultural aspects
The Blackfriars Street Bridge (BSB) was manufactured by the Wrought Iron Bridge Company (WIBC) of Canton, Ohio, although erected by local London contractor Isaac Crouse. There is evidence for its being prototypical for a revised design by WIBC, incorporating a double-panel web.[3] The BSB is the successor to a series of fixed, wooden structures at the site since 1831, which were damaged mainly by spring "freshets" of the river.[4] It has been designated a historic structure under Part IV of the Ontario Heritage Act. The BSB is the northernmost and oldest of a company of eight bridges of different ages, constructions and uses,[5] surrounding the confluence of the North Thames and Thames rivers, which fixes the historic center of London. The Bridge is sited at the east end of a short Blackfriars Street,[6] which turns sharply south and up a slight grade, as the downtown Ridout Street, upon crossing it. To the BSB’s west is the lower ground of the previous town of Petersville, protected by an extensive dike embankment, due to a history of flooding; to its east a terrace rises above the North Thames River to central London.[7] The river there is bordered on both sides by extensive bicycle and walking paths, and the Bridge is well framed by a variety of second-growth trees.Much of the "beauty and appeal" of the BSB is its appearing to float, from many profile views provided on both banks of the gently winding river, up and downstream. That is owing not only to its strung-bow shape but also to its light placement, at its very tips, upon modest granite abutments—a feature rare among more modern tied-arch bridges. These abutments bear the passive vertical load of the open structure itself. However, the varying ‘live’ thrust forces of traffic downward on its deck are translated by the bowed chord above into horizontal tensions along the longitudinal iron eyebars of the ‘string’ or bottom chord running parallel to the deck.
The Blackfriars Street Bridge has figured in various artistic works, visual and literary, including a series of stained glass windows by Ted Goodden. Nathan Holth praises the City of London and the Province of Ontario for maintaining its old iron bridges. Regarding the nearby, larger pony-truss Kensington Bridge he praises the City for "keeping the Thames River looking wild and natural," even near its center, with the look of "a rural bridge in an urban environment, which further enhances the beauty of the bridge",[8] a remark that would apply as well to the Blackfriars. With recent improvement of the rivers, wild nature seems to confirm the point.[9] (See, below, resident Great blue heron in winter.)
Blackfriars Street Bridge, from North, winter 2007, heron.jpg – photo PM[edit] Notes, including external links
1.^ F. Michael Bartlett and Dana R. Tessler, "Wrought-Iron Bowstring Bridges: The One-Hit Wonder of the 1870s", 7th International Conference on Short and Medium Span Bridges, 2006, Montreal. For discussion of other extant bowstrings in the North American Midwest, see Holth[1]
2.^ Nathan Holth, "Historic Bridges.org" [2]. This site features a map and many structural photographs of the Bridge, with close commentary expanding on the details cited here. The raised pedestrian guardrail is likely owing to the original’s being less than 31 inches or 80 cm above an outward sloping snowpack after heavy snows.
3.^ "The bridge is one of the first to feature a ‘double-panel’ web diagonal arrangement that was patented in America one year after the bridge was constructed….The patent highlights the structural contribution of these members… and because their participation can only be accurately assessed using modern computer analyses, Blackfriars Bridge may have been built as a prototype to validate the double-panel design feature." F. M. Bartlett, J. M. Graham and J. Camiletti, "1870s Innovation in London Canada Blackfriars Bridge", Proceedings of the Institution of Civil Engineers (EH003, 2009): 1-7. This allows the substitution of verticals rods for posts in the center.
4.^ London Free Press (28 September 1875). In 1861 that newspaper had reported that in a "freshet" of almost twenty feet a wooden bridge "erected by subscription last fall" was carried away in a day. This was the only river crossing to the north: thus the iron bridge investment of $10,000 in 1875 (ca $180,000 today).
5.^ These include two pony-truss bridges, the Kensington and the Victoria (the Ridout Street crossing of the other river branch); a Pratt (see truss bridge) deck-truss, iron, railroad bridge; and the little metal-pinned, Pratt, through King Street Bridge (1895), now a pedestrian walkway. See Holth, [3].
6.^ Though long enough to be the childhood home of Academy-Award winning screenwriter, director, producer, actor Paul Haggis, whose production company is named "Blackfriars Bridge Films". See IMDb listing [4].
7.^ The broad, shallow valley of the Thames is the path of the westerly-flowing meltwater of glaciers from the last ice age, ca 15,000 years BP. (See Thames River (Ontario).) For information on Petersville and the flood, see "History", London, Ontario.
8.^ See Holth, [5].
9.^ 2007 Upper Thames Conservation Authority assessment
[edit] Handcraft repair/structural views, Winter & Spring 2008
Damage to wooden deck surface, February 200.
1. Spring 2008 renovation project begins: lifting stringer wooden cladding.
2. Deck structure: nine I-beam stringers cross two transverse floor beams; four eyebar ‘strings’ on upstream bow catch light (left).
3. Renewed stringer cladding, west abutment4. Handcrafted deck surface
5. Routing for deck plates
6. Painting dado
7. Surface plates renewed8. Welding deck steel members
9. Lifitng walkway surface
10. Walkway cantilevered on floor beams
11. Restoring restoration–not original, older replacement side-plate bolts and hex nuts12. Tension connectors of upper & lower chords
I hope that wasn’t a copy and paste job Derek…and that you typed it out out this morning at 5.33am 😮 over your corn flakes, all from memory
Can you highlight the bits i need to read Derek…. or I wait for it to appear on the history channels 🙄 :lol1:
hi lads i would speak to john i just forwarded a text he sent me
quote Derek Heron:hi lads i would speak to john i just forwarded a text he sent me
Twas not me – honest :lol1:
This is Sad, Very Sad!
How did we get from a beautiful woman on a board! To how bridges are made,
Shouldn’t it be the other way round. -
Hi Ray, After seeing Newburn bridge you wouldn’t look twice at the women on the sign – its a beauty :lol1:
Sorry, i’ll get me coat
quote RayRosher:This is Sad, Very Sad!
Shouldn’t it be the other way round.Beautiful women get older, and wrinkly. bridges stay as beautiful as the day they were built, and never need a new frock….
