Home Forums Sign Making Discussions Graphic Design Help How many pixels does this need to be?
  • How many pixels does this need to be?
    Posted by Warren Beard on 18 April 2012 at 15:50
    ‘ello
    I need to know what the minimum Amount of pixels a print must be to retain photo quality?
    eg size. 4 meters wide by 3 meters high.
    As I said photo quality as it will be seen close up, not sure what this would need to be as not done anything at this scale before and not sure if there is an easy way to calculate it?
    any help appreciated
    Warren
    Neill Jackson replied 13 years, 8 months ago 4 Members · 4 Replies
    18 April 2012 at 16:12
    i would start at around 75 100 dpi full size about 500mb then see if i got myself in a knot.
  • Stephen Morriss
    18 April 2012 at 16:17
    Not sure of the final pixel size but you need to be looking at around 160 – 180 dpi at final print size.
  • David Rogers
    18 April 2012 at 20:41
    12" away – 300dpi, 2-3 feet, bare minimum of 150 dpi – 70 dpi if over 4-5 feet
    4000mm / 25.4 = 157.5" x 150 dpi = 23622pixels wide
    considering photoshop is happy handling up to 30,000 pixels in any dimension, it’s not a massive file.
    dave
  • Neill Jackson
    25 April 2012 at 20:43
    Hi Warren,
    Dave is spot on (and a great way of explaining) minimum pixel per inch ‘V’ distance away but you can always go higher. I’m a graphic designer and would accept these as a minimum but a photographer would want it higher, 600 DPI plus.
