Home Forums Software Discussions Corel Software how does corel draw 12 compare to previous versions?
  • how does corel draw 12 compare to previous versions?
    Posted by Ryan Fairweather on 24 January 2006 at 13:13
    Anyone have any thoughts on this new version? How does it compare to versions 8/9 etc… thibking about updating today but thought it would be wise to check with you guys 1st!
    thanks
    Stephen Sill replied 19 years, 10 months ago 5 Members · 16 Replies
  • 16 Replies
    24 January 2006 at 13:26
    12 is fine, much better when it has SP1 applied
    The new version has just come out… Corel Draw X3.. so I would have a look at that
    Although a few comments of installing the trial version has been 50/50
    24 January 2006 at 13:29
    Either V12 or X3 will have plenty of new stuff over V9. X3 has got a better trace option, node reduction is enhanced plus plenty more, X3 has updated import and export filters and this includes pdf, was there anything specific you wanted know?
    Alan D
  • Ryan Fairweather
    24 January 2006 at 13:38
    mostly if they had modified areas such as auto trace etc..which quite franky on Corel 9 is useless.
    Start of the new year etc…always a good time to think about updating.
    I have found version 9 to be getting rapidly outdated.
    24 January 2006 at 13:44
    i have tinkered with Corel Trace 11 & 12, quite useful. Not sure about autotrace, not even sure if it is there still.
    24 January 2006 at 14:02
    Corel Trace is not a separate application in X3 but is integrated and called Power Trace (select bitmap – right click – left click trace bitmap), Auto trace is gone. Power Trace is is more accurate than Corel Trace (I recommend clip art setting) and good for colour. For those who still want Corel Trace it is still available from the Application Launcher, this assumes it has been installed from a previous version. I would add that Power Trace does NOT have options like Wood cut and Centreline these may or maynot be added in other options later.
    Alan D
  • Ryan Fairweather
    24 January 2006 at 14:08
    wealth of information! think i may settle for version12 as x3 is pretty steep!
    Thanks for the advice. Think im going to like this website 😀
    thanks again
    Ryan
    24 January 2006 at 14:18
    the only real reason I upgrade Corel version is so I can import Illustrator/PDF files and handle new versions.
    You will find Corel 11 &12 almost identical.
    24 January 2006 at 14:20
    I f you have any previous version of Draw I would wait until middle February when the boxed X3 is widely available and then look up the upgrade price at Amazon or Insight, it may suit your pocket better.
    alan D
  • Stephen Sill
    25 January 2006 at 13:46
    Ryan- I use 12, and I was amazed at how much better it is than 9. Since x3 is in the works, you might also find the price of 12 dropping. Do make sure you have enough memory and drive space on your system.
  • Ryan Fairweather
    25 January 2006 at 13:53
    thanks for the tip, have ordered version 12 as,like you said, prices have already reduced dramatically and i got a really good deal!
    thanks for all you help
  • Clive Darbon
    25 January 2006 at 16:09
    Ryan
    I am also thinking of buying Corel 12, and reckoned the price would drop once this X3 version appeared? Would be very grateful if anyone could point me in the right direction where I could purchase the software on a reasonable deal – ‘cos put bluntly I’m a bit skint! Thanks in advance.
  • Ryan Fairweather
    25 January 2006 at 16:18
    just bought an unregistered, still boxed and wrapped from ebay for £79+postage.
  • Clive Darbon
    25 January 2006 at 16:24
    Ryan, that sounds good. I also saw similar deals on Amazon? By the way does anyone know what is the best PC system to run the programme without causing upset? I currently use XP Pro, have 512 meg of ram (which I think is a bit light) and I think my processor is Pentium 2 though I would need to check? Thanks in advance.
    Spooky
  • Stephen Sill
    25 January 2006 at 17:01
    Spooky
    Make sure you get your XP pro patched with the latest service pack from MS. You should be fine with 512Mb – yes it would be faster with 1GB, but no problems to report -one of mine is using xp home with 512 and I just did a 24″x72″ full color banner of a french street scene that i printed on the DC3, and though it took a while to render at 300DPI it didn’t choke. The only thing I don’t like about CD12 is the Word perfect that comes with it – always locks up my invoice printer. I haven’t taken the time to figure out why – I just use MS Word instead
    Best,
  • Clive Darbon
    26 January 2006 at 10:09
    Hello Steve, thanks for the advice. My PC is returning to its maker this weekend where I shall ask that latest service packs are all upgraded. I have to admit that I am very lazy when it comes to that, I go to the Microsoft site and go cold when I see the list and download time (still on dial up – broadband is yet to make it to my rural corner of England)!
    Probably going to have the ram doubled to 1gb, may also have a more up to date processor fitted, depending on the overall cost. Then I’ll get myself a copy of Corel 12.
    By the way Steve, have to say that the photo makes you look like the CEO of a big corp, do you work for the ‘Big Blue Machine’?
    Cheers, Spooky 😉
  • Stephen Sill
    27 January 2006 at 15:38
    <Laughs>
    No, that’s my “working outfit” My fulltime job is with the US Govt. My sign business started out as a hobby and has kind of gotten out of hand. I <really> gotta change that pic!
