Home Forums Software Discussions Corel Software how do you turn a line into a cutpath from corel please?
  • how do you turn a line into a cutpath from corel please?
    Posted by Mike Robson on 4 August 2008 at 15:44
    Sorry if this has been asked a million times, but how do you turn a line into a cutpath from Corel. It’s for the Troop RIP
    We don’t have Corel here, it’s just to let a customer know so that they can create PDFs with cutpaths in.
    Mike
    Shane Drew replied 17 years, 2 months ago 10 Members · 12 Replies
  • 12 Replies
    4 August 2008 at 15:58
    Try Troop Help – Here is an extract from their helpfile
    The following tech note will walk you through creating a CutPath to use with Wasatch SoftRIP from Corel Draw 9, 10 and 11.
    Click on Tools and select Palette Editor.
    From the drop down menu select Custom Spot Color (Corel Draw 9 users will find this option under User Defined Inks).
    On the Palette Editor window, click on Add Color to create a new Spot Color.
    When the Select Color window opens, click on the Mixers tab.
    Select any color you want from the color wheel.
    Click on Add to Palette, then click on Close.
    For users of Corel 9 or 10
    Change the Name of the Selected Palette Color to CutPath, click on OK to save the settings. For SoftRIP to recognize the Cutting Path, the name must be CutPath, spelled exactly as it appears.
    To apply the CutPath to your artwork, click on the Outline Pen.
    Select the CutPath Spot Color, and width should be set to Hairline.
    When finished, save or print your artwork to create a .ps, .eps, or .prn file.
    For users of Corel 11
    Make sure your image is selected by using the selection tool.
    From the Outline Tool menu, choose Outline Pen Dialog.
    Select Hairline for your width.
    Next, select other from the color menu.
    From the palette tab, choose CutPath and click ok.
    Click ok again, and your image should be outlined with the CutPath spot color.
    When finished, save or print your your artwork to create a.ps, .eps, or .prn file.
  • Russell Huffer
    4 August 2008 at 16:05
    I know nothing about Coral, however belive these links may help.
    http://www.wasatch.com/flash/english/cu … orWeb.html
    http://www.wasatch.com/pdf/corelVectorCutPath.pdf
    Russell.
    4 August 2008 at 17:58
    dont think you can cut from a pdf
    prove me wrong please
    4 August 2008 at 18:46
    Is wasatch the same as troop then?
    peter
  • Mark Nihotte
    4 August 2008 at 19:55
    Follow Phils instructions and the cut path will remain as a cut path in a PDF file when created in Corel. We do all of our print/cutting as PDFs in versaworks as colours are more vibrant than EPS files.
  • Frank Horner
    Chris,
    I’m pretty sure you can’t cut from PDF, it has to be EPS to process the cutpath.
    Peter, Troop is rebadged Wasatch.
    Frank
  • M Brown
    4 August 2008 at 21:54
    yes you can have cut paths embedded into a pdf file. We use Wasatch Rip(TROOP v6) and when you have process cut paths enabled, the cut path is show as a line of moving dots, or as B&P call it a line of marching ants.
    It doesn’t matter if its a pdf on an eps file, does the same thing..
  • Steve Bird11
    4 August 2008 at 22:05
    Yes this is possible although not sure about the cut path in troop, Mines set as CutContour in Corel with the two capital c’s being critical to make it work….Like Mark said pdf colours are more vibrant than eps.
  • M Brown
    5 August 2008 at 07:30
    I call my contour cut line "Cutpath" in Corel, used the colour and thickness as suggested in the help for my troop. Imports fine as a pdf into troop and cuts just as normal.
    Will have to try the PDF vrs EPS for colour vibrancy.
    from Mark
  • Mike Robson
    5 August 2008 at 08:00
    Cheers guys. Pretty much the same process as in Illustrator then.
    Does the capital P matter? – I was told it does in Illy, but actually doesn’t.
    5 August 2008 at 09:20
    well it does not work in colourrip 2.2 but if i was to update for a fee i would.
    17 October 2008 at 11:39
    wish I had found this post before (hot)
    I always used the CutPath in colorip2.2 from Corel 12, but when I upgraded to X3, the cutpath wouldn’t work.
    Corel 12 didn’t cut in a pdf either via colorip2.2
    No one could answer why it wouldn’t work, so I’ve been doing the design in X3, saving as v12, then reopening in v12, adding the cutpath, then exporting in eps to 2.2 to RIP.
    When I upgraded to Wasatch Softrip 6.3, I still couldn’t get X3 to work with a cutpath, and I’ve tried everything.
    Killing time today, I stumbled over this thread.
    I changed the cutpath to cutcontour in X3 and it works!! 😛 and I can now cut in a pdf file too (hot) (hot) :banghead: 👿
    Thanks for everyones input here, 😉
