Home Forums Software Discussions Corel Software How do you: Sequentially number DUPLICATE NCR paper?
  • How do you: Sequentially number DUPLICATE NCR paper?
    Posted by David Rogers on 3 December 2014 at 15:26
    Setting up for a set of pages to sequentially number is OK but what I need to know is how to run it through as duplicate (carbonless NCR paper) so that there will be for example duplicate ‘001’ white page / ‘001’ blue page / ‘002’ white / ‘002’ blue / ‘003’ white / ‘003’ blue etc.
    David Rogers replied 11 years ago 4 Members · 4 Replies
  • Colin Crabb
    3 December 2014 at 15:59
    Great little programme called ‘Number Press’
    http://www.praetersoftware.com/numberingsoftware/
    Makes its so much easier :lol1:
    3 December 2014 at 17:38
    You can do this through InDesign using the Data Merge function.
    The trouble is the sheets don’t come out collated in order, but it shouldn’t be too hard to rectify that in excel if they’re A5 (4 up on SRA3).
    You’d have to reprint the job for each sheet of NCR (top, middle, bottom) and then collate them
    Depending on your printer (assuming you’re doing it digitally) you could print all the same images without numbers and then run the sheets through again with just the number overprint, with a duplicate copy for each page, and use a mixed media setting on the rip (we use a fiery rip on our xerox) to pick use a specific tray for each page.
    That will give you numbered & collated.
    Or perhaps sub it out (even if it’s just the numbering) to a 1-2colour printer, who has a mechanical numbering machine.
  • Paul Hughes
    3 December 2014 at 17:41
    what version of corel are you running?
    it easy to do, you just have to set up a mail merge and a set of numbers, let me know which version and i will write you a step by step if i can, just busy at moment but will sort it latter/tomorrow
    Paul
  • David Rogers
    3 December 2014 at 21:52
    Thanks all.
    I’ll take you up on you offer Paul. It’s for X7 on our print design PC…
