Home Forums Software Discussions Corel Software How do you get text To taper away in corel?
  • How do you get text To taper away in corel?
    Posted by Paul Humble on 12 November 2008 at 09:34
    Hi everyone,
    Im having difficulty getting text to taper away. Im not great at explaining and cant upload in this section but basically I have an image of a shutter that goes off into the distance, so I need my text to start at one size then get smaller as it goes away from you.
    Any ideas? I know it will be simple but its something ive never needed to do yet.
    Paul
    Paul Humble replied 17 years, 1 month ago 3 Members · 4 Replies
    12 November 2008 at 09:41
    It depends on the software you are using Paul. Most sign design software feature distortions that you can apply to the lettering. One of these is a perspective distortion which gives the impression of the lettering running away into the distance just as you have described.
  • Paul Humble
    12 November 2008 at 09:44
    Its Corel X3 Phill.
  • Warren Beard
    12 November 2008 at 09:49
    in Illustrator it’s under effects and is called "Warp" there are many settings there to do many different things including what you are asking, more than likely yours will be under a different name in Corel but look through the effects and you should find it.
    Sorry can’t be more help.
    Warren
  • Paul Humble
    12 November 2008 at 09:51
    quote Warren Beard:
    in Illustrator it’s under effects and is called “Warp” there are many settings there to do many different things including what you are asking, more than likely yours will be under a different name in Corel but look through the effects and you should find it.
    Warren
    That was all I needed Warren, its called "Add Perspective" in Corel. Couldnt see the wood for the trees.
    Cheers Guys.
