Home Forums Sign Making Discussions Vinyl how do you cut a log of vinyl?
  • how do you cut a log of vinyl?
    Posted by Roy Roberts on 3 November 2004 at 08:06
    😀 I Have Purchased Some Vinyl From A Friend Who Is Going Abroad, 🙂
    😕 Problem is its too long for my cutter need to cut it down to 600mm. 😕
    Any ideas the best way to Cut Logs. (!)
    Roy Roberts replied 21 years, 1 month ago 4 Members · 5 Replies
    3 November 2004 at 08:45
    If its a small quantity, one or two rolls, I would just cut it by hand with a straight edge. Or make a simple guide by clamping a straight edge or baton to the edge your table /bench (if its big enough) You can then tap a stanley knife blade into the table (eye protection advised) at an angle and about halfway along the length of the table. Put the roll at one end of the table and as you unroll it, and feed it through you blade, and re roll at the other end. Probably need 2 people to do this.
    Hope this makes sense
    Peter.
  • signworxs
    3 November 2004 at 11:31
    Ive used a band saw with a fine blade in before with reasonable results.
  • Roy Roberts
    3 November 2004 at 16:20
    Thanks Lads, 😉
    Both good ideas I will give them a try and see how I get on. 😮 😮
  • juddr
    7 November 2004 at 21:00
    take a look here http://www.rtape.com/index_files/page0020.htm
    theres a tech document called “Roll Slitting Tricks of the trade”
    cheers!
  • Roy Roberts
    8 November 2004 at 05:59
    Cheers Juddr,
    Will 😮 😮 Look into it 😮 😮
