Home Forums Software Discussions Corel Software How do I seperate oultines and text for cutting?
  • How do I seperate oultines and text for cutting?
    Posted by Oliver Holmes on 4 September 2007 at 09:01
    Hello,
    I have a really dumb question here with regard to outlines and vinyl cutting.
    I’ve just started using CorelDraw, and so far am very impressed. I’ve managed to add an outline to my text, however I can’t figure out how to seperate the outline from the text for cutting.
    This is the sort of thing I am trying to achieve:
    I would be very grateful if someone could explain how to do this to me? Or suggest a better way of creating outlines for cutting?
    Many thanks,
    Oliver.
    Hugh Potter replied 18 years, 2 months ago 7 Members · 7 Replies
  • 7 Replies
  • Andrew Ritchie
    4 September 2007 at 09:18
    I don’t use Corel much but I think it would be something to do with the shaping function? It works the same way as welding in Signlab.
    Alan Drury is the Corel guru, he’ll probably have a solution for you.
    Andy 😎
    4 September 2007 at 09:24
    with the outline selected go
    arrange
    break contour group apart
    you will then have 2 selectable objects
    what ver No are you using
  • George Elsmore
    4 September 2007 at 09:25
    type in text/click on effects/choose contour put in size of contour and check outside buttoon in the flyout/choose colours of contour etc/select all text/go to arrange click break contour group apart look in wireframe and see your cutlines
    hope this helps a bit
    G
    I am only two years into Corel 9, and don’t have Corel on this machine.
    But if memory serves, select the entire phrase.
    In the drop down "Arrange" menu, choose "Separate".
    Then de-select the phrase and select only the outline.
    I don’t cut from Corel so I have no idea about that part.
    You know not to use red as an outline color on black, right?
    It lacks contrast.
  • Gordon Galloway
    4 September 2007 at 09:27
    Duplication of advice aleready given
    Gordon 😳
  • Oliver Holmes
    4 September 2007 at 10:43
    Fantastic advice! It’s so easy when you know how.
    Thank you all for your help, it’s very much appreciated. Oh and don’t worry I won’t be using the red outline, it was just a quick image to help explain what I was trying to achieve.
    Thanks again,
    Oliver. 😀
    24 September 2007 at 09:35
    another tip.
    if you have alot of text to do, which will need layering,
    break apart all the contours,
    highlight the whole lot of text / images,
    left click (holding down), drag and right click, it will make a duplicationof the original, then just delete the image / text on one lot, and the contours on the other,
    you’ll then have perfectly spaced contour group, and original text/image group to cut.
