Home Forums Printing Discussions General Printing Topics How do i print a double sided banner?
  • How do i print a double sided banner?
    Posted by Steve McAdie on 16 June 2008 at 13:32
    I have been asked to print a double sided banner. My question is what is the best way to achieve this? Should I print on one side then turn over and try to align the print with the other side or print two off next to each other and fold over. Any help appreciated. Size is roughly 2m X 500mm on cadet plus.
    mod-edit
    Alex Wilson replied 17 years, 6 months ago 5 Members · 8 Replies
  • 8 Replies
  • David Rogers
    16 June 2008 at 13:56
    Did one a wee while ago.
    The major downside of ‘normal’ banner material is it lets light through.
    Printing on the back looks great until it’s hung up!!
    In the end – I did the two-back-to-back.
    Since then just used a total block material.
  • Steve McAdie
    16 June 2008 at 14:03
    Thanks Dave, How did you finish/join the edges? I have hemming tape but was thinking that it maybe better sewn.
  • David Rogers
    16 June 2008 at 14:22
    Taped…and a few extra eyelets.
    Thought about sewing…couldn’t be bothered!
  • Steve McAdie
    16 June 2008 at 14:25
    I can’t either think I will get the Mrs to do it. :lol1:
    Thanks for the help
  • Alex Wilson
    16 June 2008 at 16:04
    Hi All
    Hexis do a double sided block out banner which is printable both sides. I used it recently to do a couple of heavy duty flags and it worked really well on the Versacamm.
    Kind regards
    Alex
  • Jason Xuereb
    17 June 2008 at 03:56
    When you print the first side put a hole in the top right hand corner of the print. Then flip it over and put it back in the printer. Set the cutting blade to this point and hit base point. Print the second side not centered and it should come out fine.
    We did one not too long ago like this and it came out nice.
    We left the sides simply cut with no hem and just did pole inserts top and bottom.
  • MikeeWalsh
    1 July 2008 at 18:08
    Alex how did you finish the edges on those flags
  • Alex Wilson
    1 July 2008 at 19:29
    Hi Mate
    The Hexis blackout D/Sided banner material is thick enough to just cut and eyelet. they are promotional so are not used that often
    Kind regards Alex
