Home Forums Software Discussions Corel Software how do i outline blended text please?
  • how do i outline blended text please?
    Posted by Adrian Yeo on 1 February 2008 at 21:59
    Hi there
    Only having just started to play with my cadet, I have stumbled upon a problem.
    I have some blended text (using corel 11) that i want to put an outline around to cut. simple. But can I find out how to do it? can I hell!
    Using RGB 1,1,1 as my cut colour. Can anybody enlighten me please?
    Adrian
    Alan Drury replied 17 years, 9 months ago 6 Members · 13 Replies
  • 13 Replies
    1 February 2008 at 22:32
    Select the text you wish to contour cut and Right click on the colour shade that has a colour mix RGB 1,1,1 (you will have to create it) .
    Export as .eps and open up in your RIP. Bobs yur Uncle 😀
  • Adrian Yeo
    1 February 2008 at 23:34
    Thanks Phil,
    Tried that, but all that seems to happen is the blend takes on the solid colour of the outline. (If that makes sense)?
    I have attached the CDR file that I am trying to outline if anyone fancies a go? 😀
    Sorry Robert, I should have put this in the ‘Corel section’ 😳
  • Ian Bingham
    1 February 2008 at 23:56
    Duplicate the design. Un group it, weld it, and asign the welded outline as the cut path.overlay over the origanal
    Hope it makes sense
    Ian
    2 February 2008 at 00:09
    just buy signlab….
    sorry I tried it in corel, but takes far less time and effort in signlab.
    ok, I know, signlab costs a bomb, but for this kind of stuff, it just does it with one click…..
  • Adrian Yeo
    2 February 2008 at 00:13
    Oh well, at least its not just me!! 😀
    The bourbon is now having the desired effect so I will have another go in the morning!!
    Any cheap copies of signlab available??? 😀 😀
  • Peter Munday
    2 February 2008 at 00:17
    Adrian try this.
  • Adrian Yeo
    2 February 2008 at 09:10
    Thanks Peter, but it wont open! 🙁
    Was this done is X3, I have 11 here.
    Adrian
    2 February 2008 at 09:20
    converted to 11
  • Adrian Yeo
    2 February 2008 at 09:23
    Two Peters!
    You are stars!! (hot) (hot)
    2 February 2008 at 11:32
    Peter M for my information can go through the steps of how you did this?
    Thanls
    Alan D
  • Peter Munday
    2 February 2008 at 13:56
    Alan, here’s how it was done.
    Make a copy on a new page, break blend apart ( as this blend had 200 layers in it, I had to reduce it to 25) select all and weld. Then use create boundary, copy and paste on original layer, and bob’s your uncle.
  • Ian Bingham
    2 February 2008 at 17:03
    That sounds familiar :lol1:
    2 February 2008 at 17:10
    Peter, thanks that’s what I wanted to know and accounts for jaggies on slanting lines, I like to think I’m fairly up with Corel stuff and I wasn’t aware of an automatic way of doing it.
    Alan D
