Home Forums Sign Making Discussions Neon, LED, Lighting How do I make a sign tray with backlit protruding letters
  • How do I make a sign tray with backlit protruding letters
    Posted by Ruairi O'Boyle on 5 July 2010 at 09:19
    I have an customer looking a sign box made from composite panel with opal letters protruding through faced off in vinyl thus giving an edge lit type ook to the name on the sign.
    I was wondering how this is done? I suspect that the 3mm composite panels are routered and the the opal letters (5mm? too little?) are made with a recessed edge and glued into position. Is this correct?
    Has anyone any good advise for this type of thing?
    I could probably post a picture but I am not sure I am allowed in this forum.
    Below is a link which might help under stand the type of thing I am trying to achieve.
    http://www.paylesssigns.com.au/images/L … Wizard.JPG
    Ruairi
    Steve Maple replied 15 years, 4 months ago 3 Members · 5 Replies
  • Martin Cole
    5 July 2010 at 11:41
    quote Ruairi O’Boyle:
    Ruairi,
    Have fitted a couple but I’m no expert on these but I would say Fret cut tray with flat cut acrylic letters pushed through and glued to the back of letter and tray with clear acrylic tabs using a clear glue. 5mm will only give you a 2mm edge so 8mm would be preferable.
    Some good companies out there that will make it for you.
  • Ruairi O'Boyle
    5 July 2010 at 11:45
    Cheers Martin – your right 8mm would be a minimum actually!
    I might give some of the suppliers a call on this one.
  • Martin Cole
    5 July 2010 at 11:51
    Ruairi,
    I would recommend Applelec or GDI both very good and helpfull.
    You’ll find their details in the tool bar
    Martin
  • Ruairi O'Boyle
    5 July 2010 at 12:03
    cheers Martin Ill ring them now.
  • Steve Maple
    10 August 2010 at 03:01
    i reckon its
    -opal panel with no cutting – ‘diffuser’
    -fit opaque vinyl onto it with lettering cut out
    bond clear cut 10mm letters acrylic to acrylic laminate tensol
    -same drawing/file
    easy layout – just drop them in
    face the letters
    otherwise you haven’t got a light source into the clear letter, so to refract out of the sides
    -i remember doing some glass table tops with yellow light – twas years ago though
