Home Forums Software Discussions Signlab Software how do i import a word document into signlab?
  • how do i import a word document into signlab?
    Posted by LeeMorris on 14 March 2007 at 09:55
    Hi All
    I have a document thats in word just some writing and small image all in black and i want to open it in signlab how do i do this , i need the image more than text i can just re write that part.
    Lee
    Rod Young replied 18 years, 9 months ago 3 Members · 5 Replies
  • Andrew Ritchie
    14 March 2007 at 09:59
    Hi Lee,
    Try zooming in as close as you can get and hit "Print Screen" button".
    Alt+Tab or select Signlab from the taskbar and paste into your workspace.
    Thats the way I woould do it.
    Andy 😎
  • LeeMorris
    14 March 2007 at 10:35
    Hi Andrew
    Thanks thats a really good trick a lot cleaner than scanning, Its crazy the little things you never knew about that make life so easy.
    Did it with alt+tab . Whats the print screen button?
    thanks again
  • Andrew Ritchie
    14 March 2007 at 11:03
    Its the button on your keyboard. At the top usually next to "Insert, Scroll Lock" etc…. Only thing is, it will grab the screen at 72dpi 😕
    Andy 😎
  • LeeMorris
    14 March 2007 at 11:31
    It works if i drag and drop it into signlab but only does it in sections, using the the print screen and paste it turns out like a big mass of black mess.
    Lee
  • Rod Young
    14 March 2007 at 15:42
    Might be an easier solution:
    1. Open the DOC file in Word.
    2. Select the image.
    3. Perform a copy operation (Edit >> Copy).
    4. In SignLab, perform a paste operation (Edit >> Paste).
    Alternatively, select the image, and then drag-and-drop into the SignLab window. Press [Ctrl] when doing this to create a copy.
    Cheers,
    Rod at CADlink
