Home › Forums › Sign Making Discussions › Computers – Tablets – Phones › how do i get the pound sign on my keyboard?
Posted by Brian Little on 11 August 2007 at 09:18hi folks got a problem with keyboard …im sure its simple enough to fix …but i dont know how .I need a pound sign …and it comes up a hash its been doing this for ages ive not bothered with it …now ive got cars to do this morning in a showroom ..eh HELP!!!!.
Ps ive changed the keyboard but no joy
Brian Little replied 18 years, 5 months ago 7 Members · 16 Replies -
you have the computer set for USA, go to Control Panel then Regional & Language settings set to English.Hope this helps
You need to set the language for the key board Brian
control panel > regional and language > advanced > select a language set to English (United Kingdom)
Good morning Brian,
Have you tried setting up the keyboard through the control panel? Has your OS been set up to use a UK keyboard? Are your regional settings set to UK?
Alan
hmm done that guys …..the currency is set at pounds……and its set to english united kinddom …and pressed the apply button ..no luck
u need to restart the program you was using or reboot after a keyboard change.
Also, in bottom right corner you may have US or UK next to the time, make sure it says UK or something like that.
If struggling really badly
Double click on the Pound symbol above, right mouse button and Copy, then go to your design software and into Text edit, then choose Edit / Paste or press Ctrl-V
cheers guys ive went into other garage stuff and used one of those pound signs …ill work on it when i get back …as usuall time aint on my side ….your help is appreciated as usual ..have a good weekend
all keyboards are the same… its windows that changes it
Control panel > Regional and Language Options and change every setting that says United States to United Kingdom
Brian,
Hold down "ALT" and press 1,5,6 and you get a lovely "£" symbol.
Andy 😎
hmmm ive just tried that Andy in the tex comp box and nothing …really weird ive never changed any of the settings
In control panel > regional and language is regional options set to English(United Kingdom) Brian?
if you’ve never changed any settings you could try "system restore" to a few days before problem started.
When doing the trick i mentioned make sure its on the number pad you type the numbers whilt holding down "alt" after last digit let go of "alt" and a £ symbol shol appear in your text compose box.
Andy 😎
YIPEEEEE!!!! that worked ….im now the proud owner of £ signs ..i should say im writing this from the laptop in case you wondered where the pound signs came from on this 😀 As i have said im still using 98 for the cutter and signlab 4.95 ..i know iknow it belongs in a museum but it does the job for me .I went into keyboard settings as well as regional …in keyboard settings it was English {united states } that i couldnt change as it was asking for the windows 98 disk.The comp was built just recently for me so i dont have the disk ….Anyway ive got my pound signs and thats all that matters ..thanks my friends speak later
Brian, glad to hear you are sorted, nothing wrong with windows 98 apart from the fact that Microsoft don’t support it any more.
I still run a laptop on windows 98 because Inspire Pro won’t run on anything above 98. Don’t connect to the internet with it though, use a different laptop or desktop machine for that. -
cheers Martin ….thats whats great about the boards …theres always somebody thats had "the problem" or knows how to sort it 😀 :
