Home Forums Software Discussions Signlab Software how do i get signlab 6 to work with pnc1000 cutter on xp?
  • how do i get signlab 6 to work with pnc1000 cutter on xp?
    Posted by ntdudedd on 23 January 2008 at 12:44
    Have recently upgraded computer to windows xp, the cutter appears to work for random intervals but then goes erratic. I use a parallel cable setup. Can anyone help, I have treid so many drivers its crazy. Have also contacted cadlink tech support but still waiting for response?
    Frank Droog replied 17 years, 10 months ago 2 Members · 2 Replies
  • David Rogers
    23 January 2008 at 13:51
    Are you using the PLOTTER SPOOLER?
    If not I would certainly suggest that first.
  • Frank Droog
    23 January 2008 at 13:57
    I would give Davids idea a try first.
    If that doesnt work, 2 suggestions.
    1: Change your parallel port to SPP (standard parallel port)
    Its probably on ECP or EPP and the old roland wants a standard 4 or 8 mhz parallel port.
    2: Get a serial cable , or a USB to serial cable and connect via Serial.
    9600 baud is 9600 baud no matter what the OS.
    frank at cadlink
