Home Forums Software Discussions Flexi Sign Software how do i get rid of the contour cut line command?
  • how do i get rid of the contour cut line command?
    Posted by Adrian Neill on 10 July 2007 at 10:26
    Hi all …. sorry this is a very simple question, but can’t solve it.
    I have a design saved with a contour cut line. I need to use the same logo
    in another design but don’t want the cut line anymore.
    Question is, how do i get rid of it ??
    Adrian Neill replied 18 years, 5 months ago 5 Members · 7 Replies
  • 7 Replies
    10 July 2007 at 11:20
    dont you import it then remove the cut path ?
  • Adrian Neill
    10 July 2007 at 11:25
    Hi Chris ….. i imported the job before from a .Ai file and added the
    contour afterwards and saved the logo. Doesn’t seem to want to let me
    take it off again now.
    I’d usually just re-import the file, it’s just this time it’s a crest and is
    quite involved to re-colour. I have done that this time as i couldn’t take
    of the cut line ….. would just be handy for future reference. 😀
    10 July 2007 at 11:57
    if the cut line is part of the design eg contains a colour then undo its cut command, it should then only print.
  • Alan Cooper
    10 July 2007 at 16:13
    If you highlight the object that’s got the contour on it, and you right click the mouse, it says "undo contour cut".
    Alan
  • David McDonald
    10 July 2007 at 16:45
    (It will only say ‘undo contour cut’ if adding a contour cut was the last action you made.)
    Make sure the contour cut line isn’t grouped with anything else. Then select the contour and go to the Arrange menu tab, Select Contour Cut and then select Release Contour Cut.
    If you can’t select the contour cut then the imported AI file might include masks – select the part you want, right click and select un-mask, a black rectangular mask appears, deselect all, select the mask and delete it, repeat the process until all masks are deleted. then select the contour and follow the steps above.
    Macky
  • Gordon Forbes
    11 July 2007 at 01:09
    highlight right click mouse select CLEAR contour cut
    Goop
  • Adrian Neill
    12 July 2007 at 09:08
    BRILLIANT !!!! that worked !!!!
    Thanks for your help. 😀
