Home Forums Software Discussions Flexi Sign Software how do i change the blade offset setting in Flexisign?
  • how do i change the blade offset setting in Flexisign?
    Posted by Sam Millin on 27 December 2006 at 16:53
    hi,
    Does anyone know where in Flexisign I can change the blade offset setting?
    Been taking a look around and havent found it yet.
    Sam
    Sam Millin replied 19 years ago 6 Members · 9 Replies
  • 9 Replies
    27 December 2006 at 18:11
    I know its really boring but if you have a look in your flexi manual it explains all about off set and how to set it. The manual is actually very good for flexi.
  • John Childs
    28 December 2006 at 00:03
    Why bother? Why not just change it on your cutter?
  • Sam Millin
    28 December 2006 at 00:05
    hi john,
    I have a Creation Pcut630 and I haven’t seen anything on the menu which mentions Blade Offset?
    Sam
    quote John Childs:
  • John Childs
    28 December 2006 at 00:33
    Sorry Sam, I don’t know your machine so I can’t offer any specific guidance, but every cutter I have ever owned had had the blade offset adjustable somewhere in the menus.
    I would have thought it essential as the cutter manufacturers don’t know what their machines are going to be driven by. It should be possible to drive one without a pc at all!
  • luke bremner
    28 December 2006 at 08:25
    dont know about pcut machines but i have used a refine its a cheap plotter as well, you could not change the offset. I would think you will have to try differrent blades insted.
  • Gareth.Lewis
    28 December 2006 at 09:23
    In ‘production manager’ (Flexisign’s cutting facility) there is a facility to change the settings of your chosen plotter. I have a cheapo Chinese plotter and find it necessary to change the offset now and again. Try going to ‘setup properties’ in production manager and then the ‘cut’ tab, and the ‘knife offset’ alteration should be possible from there. The smallest measurement alteration makes such a difference so small steps are needed.
    Hope this helps
    Gareth
  • Sam Millin
    28 December 2006 at 11:15
    quote Gareth Lewis:
    Hope this helps
    Gareth
    hi,
    thanks a lot gareth, ill go take a look.
    Sam
    28 December 2006 at 21:10
    sorry, didn’t realise I was was using Lynn’s computer, so
    have edited.
    Peter NOT Lynn
  • Sam Millin
    29 December 2006 at 08:24
    hi,
    cheers gareth, thats helped a lot, now its time just to tinker around with it and find the best settings.
    thanks
    Sam
    quote tesselate:
    quote Gareth Lewis:
    Hope this helps
    Gareth
    hi,
    Sam
