Home Forums Vinyl Cutter Discussions Graphtec Vinyl Cutters How do I calibrate X and Y on a Graphtec FC8600
  • How do I calibrate X and Y on a Graphtec FC8600
    Posted by Simon Worrall on 23 August 2018 at 22:46
    I recently noticed that the X and Y cuts were not identical on my Graphtec.
    To test this, I plotted a 600mm square, and measured both sides of the square.
    The machine is short by just over 1mm over 600mm on the feed axis.
    This is consistent, so there is no slippage.
    Where is the adjustment for this anyone?
    Thanks.
    Simon Worrall replied 7 years, 4 months ago 2 Members · 2 Replies
    24 August 2018 at 17:41
    Manual is here: http://nepcosignsupply.com/store/pc/cat … 00USER.PDF
    Page 7-13 from a quick search I’ve done of it. :thumbsup:
    May be easier to do a 1000x1000mm, to work out the % to scale it by.
    You can also adjust it for the ARMS system, but that’s done differently, from memory using an A4 chart.
  • Simon Worrall
    24 August 2018 at 21:31
    That’s it David!
    Thank you so much.
    Simon.
