Home Forums Software Discussions Flexi Sign Software how do i bend a graphic in flexisign please?
  • how do i bend a graphic in flexisign please?
    Posted by Matt Pike on 9 December 2007 at 22:49
    Howdy 😀
    I am using Flexisign Pro 7.6 v2 and all I want to do is take a image, and bend it in a slight arc to the dimensions of a 17" circle.
    I just want the word Yamaha and a symbol to cut to put on my motorcycle wheel but it has to be at the same curvature as my 17" round rim.
    I have been looking for a way to bend my graphic image in a arc but cant fathom it.
    Any ideas anyone please?
    Many thanks.
    Matt
    RayRosher replied 15 years, 3 months ago 12 Members · 22 Replies
  • 22 Replies
    9 December 2007 at 22:53
    I dont know flexi Matt but it should be quite simple. not many people around just know, I would try the help files in flexi if you need a quick answer
  • Matt Pike
    9 December 2007 at 22:57
    Hmm am reading the help file now, can find info on turning text into a arc but not a graphic.
    If I fathom it I will be sure to update the post with the answer for anyone else who may have this problem, but as it stands I cant work it out.
    Cheers anyway Peter 🙂
    9 December 2007 at 22:59
    maybe something like fit object to path?
    What cutter do you have Matt?
    9 December 2007 at 23:02
    trace or take a photo of the bike…then import into software and match it to the curve 😀
  • Matt Pike
    9 December 2007 at 23:03
    Fit object to path, that sound good to me 🙂
    I’ll see if I can work that one out, not sure if I have to create a 17" diameter circle first then find the fit object to path symbol ?
    I have a Foison C24 cutter, and still very much learning lol.
    9 December 2007 at 23:06
    i was going to say put up the graphic ,but you cant here.
    i learned how to in coral the other week. before you all start its not the normal arc command or distort.
    9 December 2007 at 23:09
    I may be leading you the wrong way, but in signlab, I would draw the arc, then select it and the graphic, then click on fit object to path.
    Not much help….am I
    9 December 2007 at 23:11
    peter will that arc a logo
    9 December 2007 at 23:20
    quote Chris Wool:
    Said I wasnt much help didnt I.
    I would use transformation, and fit to circle for a logo
    Sorry 😉
  • Matt Pike
    9 December 2007 at 23:25
    Thanks for your help so far guys.
    Here is an image to better explain what I want to achieve :
    I need the blue Yamaha and symbols to bend to that contour.
    I could do with knowing what icons to click etc as some of the terminology escapes me 😳
    9 December 2007 at 23:28
    The "yamaha" I would use a transform or distort command. the tuning forks, just rotate to suite
  • Matt Pike
    9 December 2007 at 23:50
    Yeeeeeha 🙂
    Thanks for your advice Peter, I cracked it 😀
    So for anyone else that wishes to do this in flexisign you need to select the image, compound it, then its Effects, Distort, then choose the distorted shape in design central and drag to suit.
    Whola ..
    Many thanks again Peter for the tips.
    Matt 🙂
  • tived
    7 January 2008 at 06:38
    sorry if I am off-topic
    but you could use image wrap in PS and you should be able to bend it and even better yet use it as a smart object.
    Hope this helps
    Henrik
    PS I think this could be done in PS CS2 as well
  • Phil Price
    7 January 2008 at 07:58
    Hi there,
    Make sure you use the correct Yamaha logo. The one that’s displayed is for Yamaha Musical Instruments. The ‘M’ in the Yamaha Motor logo is different from that of the Instruments one.
    Regards,
    Phil
  • Graeme Harrold
    7 January 2008 at 08:11
    quote pancakedesigns:
    Hi there,
    Regards,
    Phil
    Just had a look on BOW out of interest, and there is no continuity, definitely no defined difference between the Yamaha sectors. Even on the bikes/motorsport logos, some of the center descenders on the ‘M’ touch the base line, others are just short.
    Yamaha global use the M as above, however when you move to their motor powered equipment site, the center descender does change to one that touches the baseline.
  • DaneRead
    15 January 2008 at 12:15
    hi only saw this now (been on holiday just got back) maybe a bit late? You must use the distort tool or alternatively if you have it as a font then you can use the text tool that types on top of curves, you can then in the design central adjust the height that you want the letter above the curve line.
    hope this helps
  • adamck
    1 February 2008 at 10:14
    Im trying to also achieve this but not 100% sure on the curves ive created.
    How do you know how much to curve/distor the text to match a 17" motorcycle rim?
    I need to created text (like you) and make rim tape.
    Im using artcut, i can curve the text but it can be set to a diameter.
    I know my wheel is about 45cm width and heigh (i think) and about 0.5mm thick.
    Ad.
  • Kieran Nolan
    10 August 2008 at 16:10
    hi folks.. its easy if you just ”Arch” the graphic.. not ”Arc” it.. Ok, it took me ages to work it out also,,, but i knew there was a way..
  • John McNickle
    22 July 2010 at 13:17
    Matt you hold down on the text tool icon and it displays 4 different text styles, the 3rd one is "path text tool" then click on your line you want to follow and type away, then change the bits you dont like 🙂
  • Graeme Harrold
    22 July 2010 at 14:39
    Hopefully its all sorted by now, otherwise that’s one very patient customer :lol1: Thread is 6 months old 😳
  • John McNickle
    22 July 2010 at 15:18
    well heres hoping
  • RayRosher
    9 September 2010 at 08:58
    Another way in Flexi 8 is to left click on the text tool (left-hand -sideof the screen)
    and select the second text tool
