Home Forums Vinyl Cutter Discussions General Cutter topics How do I add abrasive guard
  • How do I add abrasive guard
    Posted by Dave Bruce on 6 May 2006 at 20:12
    Can someone tel me how I add abrasive guard to the finished print on my Gerber Edge? I have been in to Print setup and Finishes where the flood coating etc is but it won’t allow me to untick no finishing.
    I am using Signlab7.1
    Dave Bruce replied 19 years, 6 months ago 3 Members · 7 Replies
  • 7 Replies
  • Marekdlux
    6 May 2006 at 20:15
    Sorry Dave, I’m on Omega.
    Print Options/backing-finish/abrasion guard
    -Marek
    6 May 2006 at 20:33
    Dave you need to make sure you have a spot foil pallette as your default.
  • Dave Bruce
    6 May 2006 at 20:35
    I am sure I do Peter but will check in the morning.
    Oh yer, why is the background black when I go to print/cut?
    6 May 2006 at 20:41
    You must have black as your substrata, click on the layer set up and choose the print and cut option, and type and colour vinyl you are using.
    I normally set the pallette, halftones and substrata to load by default.
  • Dave Bruce
    6 May 2006 at 20:44
    Thanks Peter, I’m sure substrata is set to white, it just changed at some point, just to anoy me.
    6 May 2006 at 20:46
    Dave, it hapens if you open a file that wasnt created as print and cut, it opens with the original pallette and no print info.
  • Dave Bruce
    6 May 2006 at 20:54
    Ah that’s the reason then Peter as most of my files are created on 7.1 without thermal add on.
    Thanks for that, I will correct it tomorrow.
