Home Forums Software Discussions Adobe Software how can I get just the outer line of the stroke?
  • how can I get just the outer line of the stroke?
    Posted by AG Martin on 24 May 2007 at 17:37
    Hi all
    Quick question for illustrator just started cutting from it
    If I put a Stroke on the font to give it a larger appearance then outline the font how can I get it just the outer line of the stroke is my cut line I have tried outlining stroke but then I have about 3 paths.
    thanks guys
    martin
    AG Martin replied 18 years, 4 months ago 4 Members · 4 Replies
  • Martin Grimmer
    24 May 2007 at 17:50
    Use the direct selection tool (the white arrow) to highlight the additional lines you dont want. Ctrl + Y will get you in and out of outline mode quickly to check. (think you can also click on a node in outline mode with the direct selection tool, delete once to delete the node, press delete again and it will get rid of remainder of line).
    Hope helps.
    Martin
  • John Childs
    24 May 2007 at 21:31
    It sounds like you are doing it right – outlining the strokes.
    After that, like Marts said only – put a little more simply – select the paths you DON’T want, and delete them.
  • George Kern
    25 May 2007 at 01:09
    create an offset path save it to a seperate layer and only cut that one.
  • AG Martin
    17 August 2007 at 12:58
    Hi Guys
    The easyest way I find to do it is to –
    – create you text with outline
    – outline font
    – outline stroke
    – select all and un-group
    – in the pathfinder pallet click add to shape area then expand
    sorted, dont know if this is easy for you but saves selecting individual letters
    mart
