Home › Forums › Printing Discussions › General Printing Topics › hot or cold laminator what is best
Posted by Ian Pople on 14 August 2008 at 20:25Hi,
Please can you tell me if a hot laminator is better than a cold laminator.
Ian
Chris Wool replied 17 years, 4 months ago 3 Members · 6 Replies -
Yes it is.
Hot reduces, or eliminates, silvering and makes the colours more vibrant.
just a note as john says and really does make a difference to the finish. but some are listed as hot but only go to 40deg. as mine does. which is fine for normal use.
what one is suitable for banners?
ok very noob question sorry
no need to laminate banners they are uv inks or solvent.
judging by your questions you need to understand there are 3 basic different inks.uv cured outdoor & indoor
solvent out or indoors
water based mainly indoor limited outdoorthe nova printer is water based.
Thanks for the reply trying to learn loads of new thing in a shot space of time. I have found some old specs and it States –
DYE AND PIGMENT INK FLEXIBILITY
The NovaJet 750 has eight ink lines and eight ink reservoirs, so switching between indoor and outdoor ink sets is as easy as swapping out the four ink cartridges. Newly re-designed quick disconnect cartridge valves and septum connectors make changing cartridges mess free.So the novajet is no good for banners?
Ian
both dye and pigment they describe are water based and its really the materials that let the system down. there are one or two expensive exceptions.
