Home Forums Printing Discussions Sublimation Printing Hi vis & vinyls
  • Hi vis & vinyls
    Posted by Neil Speirs on 8 April 2009 at 19:01
    I usually sub all my hi vis garments but I’ve just been asked for a load of blue vests with white text for a racecourse. Apparently the hi vis yellow & orange vests can distract the horses and greens don’t distract them enough 😉 so it’s gotta be blue
    Anyway I’m not to sure if the standard xpres super flex is good enough for the job because I’ve seen loads of workies in the past with high vis jackets & vests and half the print missing or hanging off (not mine) Anyone any recommendations for vinyl to avoid this?
    ta
    Neil Speirs replied 16 years, 8 months ago 7 Members · 8 Replies
  • 8 Replies
  • Tracey Little
    8 April 2009 at 20:05
    Hi………..I have always used Cotton Flex from either Merlin or Doro Tapes – never had a problem with letters coming off. Hope that helps
  • Kevin Talbot
    8 April 2009 at 20:18
    Superflex is fine, been using it for years with no problems at all. Kevin
    9 April 2009 at 06:50
    hi vis vests are usually 100% polyester, so i would just be certain that the garment vinyl is suitable before pressing.
  • Earl Smith
    9 April 2009 at 08:38
    I dont know much about it but I do know that there is a special vinyl for printing onto poly. Somewhere in its structure there is a layer which stops the colour of the garment sublimating out through the vinyl and changing its colour. Its used on Polyester football kits.
    Sorry I cant be of more help.
    Earl.
  • Neil Speirs
    9 April 2009 at 09:11
    Thanks guys, I’ll give xpres technical a call and see what they say on it
  • Stuart Davies
    9 April 2009 at 15:52
    let us know what they say please
    stu
  • Steve Underhill
    9 April 2009 at 21:14
    I dye sub all mine, its way easier, but if I have to use superflex as mentioned above, or nylo flex both from xpres.
  • Neil Speirs
    11 April 2009 at 22:40
    quote Stuart Davies:
    stu
    I’ve had no luck on getting through to them yet but feel quite confident that superflex will do the trick after hearing from Kevin & Steve.
    Just need to see if I can get some inside winning tips for saturdays big race now 😉
