Home Forums Sign Making Discussions Off Topic Chat Hi from Drumnadrochit
  • Hi from Drumnadrochit
    Posted by Rab on 23 May 2003 at 08:47
    Hi all,
    Just saying hello, we’re not principally sign-makers but do the odd job here and there and would like to learn how to do this better and also use some of these techniques on our giftware products.
    We have a β€˜New Star OM40’ Cutter which is mainly used for doing T-Shirt transfers but cuts sign vinyl as well and a Roland PNC2300 engraver / router (which is for sale)
    I’ve just designed and built our own CNC router, 1.2m x 0.5m with 5-axis capability, having previously converted a small mill to a 5-axis router and wrote a software plugin to make the cutting paths. The router was built primarily for carving wood but can be used for foam, mdf, etc.
    I hope I can get some advice here on;
    Router cutting bits
    Materials
    Vacuum hold down
    Cutting vinyl on a flatbed router
    Finishing / Weatherproofing
    Regards,
    Rab Gordon
    http://www.rainnea.com/cnc.htm
    Rab replied 22 years, 6 months ago 5 Members · 8 Replies
  • 8 Replies
  • John Childs
    23 May 2003 at 08:57
    I spent a day in Drumnadrochit once. It rained.
    Seriously, welcome to the board Rab. I’m sure that you will get lots of help.
    23 May 2003 at 09:03
    hi mate
    a big welcome from myself and an even bigger welcome to another scotsman πŸ˜‰
    make yourself at home.. & just get stuck in when you feel you can..
    cheers mate πŸ˜‰
  • Rab
    23 May 2003 at 09:05
    Hi Phil,
    Hoping for about Β£2k for the Roland, but if no one bites then I’ll take a serious offer. It’s surplus to requirements with the new machines, but it’s done some good stuff in its day including gold wedding rings done as flat strips then formed and soldered !
    I’m sure you can sympathise, but we get very used to spelling out every line of the address πŸ˜†
    Rab
  • Rab
    23 May 2003 at 09:54
    have many folks joined the UKSG and if so would they recommend it ?
    The how-to guides look very interesting, are they worth paying up to get access to ?
    Rab
  • John Childs
    23 May 2003 at 11:15
    Rab…
    Definitely and most certainly – YES
  • Steve Madley
    23 May 2003 at 18:40
    Welcome to the site Rab. The UKSB membership is definately worth it, I just joined a few days ago and have learned a helluva lot.
    24 May 2003 at 14:59
    Hi Rab and welcome to the boards. Even if you are not interested in saving money on materials the membership is more than worth it. You would pay a lot more for the demos, fileswapping tricks & tips if you could get them elsewhere.
  • Rab
    24 May 2003 at 15:52
    ok, ok, I’ve just signed up πŸ˜€
    Although I’m here to learn, I’ll also try to help others with some of the technical aspects of CNC routers where I can.
    Rab
