Home Forums Sign Making Discussions CNC Router and Engraving Help! Zund engineer or similar urgent required
  • Help! Zund engineer or similar urgent required
    Posted by George Neagu on 10 March 2016 at 13:36
    Hello,
    I am looking for a Zund engineer or any mechanical engineer to fix a router tool for us. It is quite urgent.
    Basically the collet of our Zund router tool snapped inside, see photo. I have contacted Zund UK but they said they can’t do it, no tools blah blah blah and offered us a new one to buy.
    We have tried to remove that but not much success, we don’t know how to open the tool.
    I was wondering if there is a mechanical engineer around here or someone who has experience with this sort of issue.
    Many thanks,
    George
    George Neagu replied 9 years, 8 months ago 3 Members · 8 Replies
  • 8 Replies
  • Kevin Flowers
    10 March 2016 at 14:21
    George
    post up some pictures, was previously an engineer and whilst sign making maintained my own router can fix most machinery. Where are you located
  • George Neagu
    10 March 2016 at 14:27
    Hi Kev,
    Sorry, forgot to attach the photo. See above.
    We are based in Camden/London NW1
    Ta
    quote Kevin Flowers:
    George
  • Kevin Flowers
    10 March 2016 at 14:53
    George
    looking at that they undo with a special socket that locks into the pinholes on the face of them rings, probs would be making a tool to work on them securing nuts, has the shaft actually broken off hard to tell from the photo’s. If it has then locating a new part would be hard, this spins at very high RPM so would require balancing on special equipment.
    Post some photos of the end of the shaft please
  • Kevin Flowers
    10 March 2016 at 14:55
    Just looked at pics again presuming you have a snapped collet in the head, are the normally just push fit screw in etc, may have an idea how to remove once i know.
    Collets on std router are different
  • George Neagu
    10 March 2016 at 17:52
    Hi Kev,
    Sorry for late answer, I did a trip to Luton.
    See image attached. The collet has thread inside to connect with the shaft. The shaft is not broken.
  • Lee Reeves
    10 March 2016 at 18:41
    Can you not drill a small hole and use either a left handed thread bolt or a tool call an easy out I think you can purchase the tool from screwfix for about £10
    Hope it helps
  • Kevin Flowers
    10 March 2016 at 20:44
    Ok i’m presuming that the bit left in is tubular if it is i would modify an easy out either making it very stubby and you may have to weld an extension for it to reach. You can make your own with a bit of flat bar cutting at a taper then grinding edges to sharp angle. Has you tap it into place it will dig in then use a pair of grips to hopefully unwind. I can come have a look if you aren’t confident to do yourself
  • George Neagu
    11 March 2016 at 09:18
    Morning,
    I have tried already such a tool but the collet feels very hard steel and the easy out tool does not get any grip on it.
    I have to go to ScrewFix to buy that tool. The one I have is from Maplin and does not get any grip.
    I also tend to believe something went wrong inside, maybe the collet has been badly screwed into the shaft, because I got grip on it with a flat end scredriver but is feels proper stuck.
    I try to call the manufacturer (a German company) to see if they can advise hot to open the router tool perhaps I will have more luck.
