Home Forums Sign Making Discussions Graphic Design Help Help with haulage logo?
  • Help with haulage logo?
    Posted by Gary Davis on 14 February 2009 at 13:08
    hi,
    I put together a logo for a haulage company and was happy with colours but now i find it has to go on a blue vehicle as well. not keen on putting a white box around it so i have played with the colours.
    2 problems….im not sure what colours to do it that doesnt look odd with the blue, i think the one below is a bit plain. I’m worried it looks abit to old fashioned?
    secondly i need to get Light Haulage in there, have tried putting Light above the haulage part and altering the spacing to cover the whole width but being such a short word in the first place it just doesnt look right
    any ideas welcomed even if completely different, ignore the tag line its just to balance the design at mo, will be changed
    thanks in advance
    gary
    EDIt the blue has come out different on the JPEG conversion imagine a mid blue!!
    Glenn Sharp replied 16 years, 8 months ago 5 Members · 7 Replies
  • 7 Replies
  • Gary Davis
    16 February 2009 at 17:25
    whats happened to this section!? have i not posted the right format or something? I have tried to post the initial idea as a start
  • Warren Beard
    16 February 2009 at 17:31
    Hi Gary
    post up an eps file and some may play around with your design.
    I would maybe add the "light" above the "haulage" with a line on either side of "light" to balance it out, it onlt needs to be small as it is secondary to the main message of being a Haulage company.
    post up an ai or eos file and people might be able to help easier.
    sorry, hope that helps a bit
    Warren
  • Gary Davis
    16 February 2009 at 17:37
    thanks warren will try the line idea to balance it, will post eps later thanks
    16 February 2009 at 19:25
    One thing I can see instantly that would help this logo is to NOT use Brush Script.
    And if you must use that font, please weld/connect the letters. A script is supposed to flow as if it was handwritten.
    edited to add pic
  • Stevo Chartrand
    17 February 2009 at 13:29
    Stevo
  • Gary Davis
    17 February 2009 at 18:18
    thanks jill, see what you mean about the script now, does look alot better. Not something i had notcied before, thanks. I will have aplay about without the script as you suggest
    thanks stevo, will see if i can incorporate all the ideas and will report back
  • Glenn Sharp
    17 February 2009 at 22:30
    Mine’s a bit basic but you never know…….
