Home Forums Printing Discussions Roland Printers Help sourcing Roland Versacamm SP 300 parts in the UK
  • Help sourcing Roland Versacamm SP 300 parts in the UK
    Posted by Lloyd Morgan on 7 February 2015 at 11:29
    hope you guys can help
    where in the Uk can i get an encoder strip compatible with a an sp300?
    i’m sure it is the strip or maybe the sensor
    i’m randomly getting 0 mm width reading when setting up the pinch rollers the are approximately 700mm apart if i keep retrying it will then pick up eventually. sometime half way through a print it starting goes very blurry. i have wiped down the encoder strip with IPA and turned it over which has helped but still i get this random issue.
    please help thanks
    Daniel Sissons replied 10 years, 10 months ago 6 Members · 6 Replies
    7 February 2015 at 13:38
    you could try
    http://www.vts-service.co.uk/
    roland UK do a parts service
    and digiprint Belgium excellent delivery service
  • Lloyd Morgan
    7 February 2015 at 13:50
    thanks Chris
  • Stafford Cox
    8 February 2015 at 17:49
    I’m not sure if you can go to Roland direct, but most official parts distributors can supply to the general public.
    The part you need is:
    21475149-00 – SHEET,LINEAR SCALE SP-300
    Roland list price £170.17 + delivery + VAT.
    Don’t forget, you can turn those encoder strips upside down if you’re desperate!!
    Stafford.
  • Graeme Dingwall
    8 February 2015 at 20:01
    I’ve just had the exact same problem and I knew it wasn’t the encoder as I changed mine last year
    I don’t think it uses the encoder for measuring the vinyl as the encoder reader is on the print head which is stationary when media is loaded.
    Anyway I think my problem was caused by the ribbon cable from the cut carriage to the main board. I just changed it and all seems good now.
    Graeme
  • Cat Wood
    9 February 2015 at 11:15
    Hi Graeme,
    As an authorised dealer we are able to source this product for you. You will find this with your standard Roland dealer too 😀
    I hope you manage to get it sorted!
    Cat.
  • Daniel Sissons
    20 February 2015 at 14:26
    You can Try Digi-print Supplies , they have them listed they are based outside UK but with Next Day Delivery
