Help recreating this sign.
Hello All,
I’m having a bit of a mind block with this sign, any help appreciated!Client would like something very similar to the Abaco sign fitted at their location. I have offered a tray but they insist they want the same shape as the abaco sign (see photo) and they would like no perspex behind the letters, and the sign illuminated.
I cant think of a way of doing it where all the guts wont be visible. The problems are that every clients walks past or drives past this sign at eye level, and the angle of the wall (the client likes the angle as they think it will be more visible from the top of the road) if it is not a tray then i don’t know what will hide the cables and the LEDs. How would you do this?
We would like to get an even halo light, and hopefully the same sort of consistent light through the letters. I think i need them to get the wall to a vertical and then that will eliminate alot of the problems? any thoughts appreciated.
the dimensions of this sign are 550mm wide by 700mm high.
All the best
Dan
