Home Forums Software Discussions Adobe Software help please trying to find photoshop clipping program?
  • help please trying to find photoshop clipping program?
    Posted by Pryam Carter on 21 April 2006 at 09:18
    A while ago l read an article in the "Signlink" magazine about a programme that acted as a photoshop filter for cutting out an object on a photo.
    It looked extremely simple and easy to use, does anyone know the name of it?
    Rodney Gold replied 19 years, 8 months ago 5 Members · 5 Replies
  • Martin Grimmer
    21 April 2006 at 09:44
    Billy,
    Haven’t seen the Signlink article – but have used Mask Pro from what used to be Extensis – they have been bought by Onone Software. I’ve used an earlier version which worked pretty well. I bought as part of their Photoshop Suite as can be expensive on its own. You can try a 30 day download. Details here if I can link properly: http://www.ononesoftware.com/detail.php?prodLine_id=4
    Corel Knockout also removes backgound but I prefer the Mask Pro.
    Photoshops own filter – extract – is pretty good too sometimes. You could extract, select and create path if you needed a cut line.
    Martin
  • Signs & Wonders
    21 April 2006 at 09:46
    I have a program called Fluid Mask that does this. It is on my Mac, but Vertus who make it have just released a Windows version.
    It is one of the best add ins I have purchased. It saves so much time and is quite easy to use.
    Tony
  • Pryam Carter
    21 April 2006 at 21:30
    Thanks for that.
    I think the one in SignLink was Fluid Mask.
    21 April 2006 at 22:01
    hm.. its very easy in photoshop… just select the areas you want then Edit / copy, new file with transparent background then paste.
  • Rodney Gold
    22 April 2006 at 03:27
    Here’s a tip , once you have a bitmap with a removed background , corel 13 has a new function called create boundry , what this does is put a vector line around any objects you select and thus the bitmap can be printed and cut VERY easily. IE if you have a butterfly and you remove background , corel will create a die line to cut it (which you can offset etc)
    Works extremely well with very complex vector graphics and so forth. Corel trace also has a remove background function if you trace bitmaps.
