Home Forums Software Discussions Signlab Software Help please, signlab vinyl output pipe error message
  • Help please, signlab vinyl output pipe error message
    Posted by Nigel Barber on 29 March 2013 at 12:31
    Hi all
    Went to use signlab vinyl went through the process to start to cut then get the error message "cannot open output pipe" i’ve re-installed the drivers for the graphtec ce5000-120 and signlab as suggested on signlabs site but still getting the issue.
    Is there something i’m missing???
    Thanks in advance
    Nigel Barber replied 12 years, 8 months ago 3 Members · 5 Replies
    29 March 2013 at 12:35
    Don’t use signlab Nigel sorry but are you cutting via usb?? If so have you checked the usb port settings within windows itself?
    If your cutting via USB do you use a converter at all?
  • Nigel Barber
    29 March 2013 at 12:53
    I do cut via usb, was working fine yesterday, as for checking the port settings, wouldn’t know where to start, not using a converter, just a usb extension, have removed the extension and plugged in to pc direct, same issue
  • Nigel Barber
    29 March 2013 at 15:34
    Right, have installed signlab and the graphtec drivers on a laptop changed the cable and still getting the message, only thing left is the machine…. any ideas people?
  • Peter Dee
    3 April 2013 at 13:52
    Nigel, I just got exactly the same thing.
    In my case it was simple; I had the wrong plotter selected in setup, having just used a different machine, I forgot to tell Signlab that I had changed back to the Summa!
    So, it suggests that Signlab found no connection on the USB or you haven’t got the plotter selected in plotter setup.
  • Nigel Barber
    3 April 2013 at 15:46
    Hi Peter,
    I did go through all the settings, spoke to Graphtec in the end, they reckon its a usb fault on the machine, as it’s showing as offline on my pc.
    Just waiting for an engineer now…..
