Home Forums Sign Making Discussions File Swapping Help Please – Remedy single font – yak
  • Help Please – Remedy single font – yak
    Posted by John Gregson on 5 November 2007 at 14:40
    Hi All,
    I need some text set in remedy single if anyone has it. Horrible font but my client insists. Could you supply, as a coreldraw file or a pdf with all fonts converted to curves, the following text:
    Jack and the ( set normal, reading left to right in lower case apart from the letter J which is in caps )
    Beanstalk ( set reading down the page one letter below the last and so on in lower case apart from the letter B )
    SMSP 07 ( all letters in CAPS )
    I would normally buy the font but I can’t see me using this font again – ever!
    Cheers John
    John Gregson replied 18 years ago 2 Members · 5 Replies
  • Jamie Wood
    5 November 2007 at 20:56
    Here you go….and you’re right, it is bleeding horrible.
    Cheers,
    Jamie.
  • John Gregson
    6 November 2007 at 10:07
    Hi Jamie, Thanks for that, just what I needed. I really appreciate it and your pints get warm just sitting here.
    Cheers John
  • John Gregson
    7 December 2007 at 21:32
    Hi Jamie,
    Thought I’d post a pic of the finished T’shirts. The font/layout and colour scheme were stipulated by the customer.
    The order of print was:
    Print Yellow then Green, wet on wet, flash dried in situe then print both colours ontop again.
    Only took 1 month to get the go-ahead from customer, then all of a sudden it turned into a rush job – as per normal.
    Thanks again for typing out the text.
    Cheers John
  • Jamie Wood
    8 December 2007 at 09:25
    Hi John,
    Thanks for posting. Good job…it actually looks better than I
    thought it would using that font!
    Cheers,
    Jamie
  • John Gregson
    8 December 2007 at 10:21
    Hi Jamie,
    The pic really doesn’t do it justice – the colours are so vibrant on the black and the majority were kids sizes so that explains the choice of font. I think they were going for that hand drawn look.
    I was suprised too with how good they looked from a basic design when I printed the 1st one off.
    Cheers John
