Home Forums Sign Making Discussions Computers – Tablets – Phones help please having problems with my network?
  • help please having problems with my network?
    Posted by Chris Wool on 28 October 2007 at 11:34
    my biannual fight with a network.
    just built a new computer trying to connect it to the network.
    well the other 4 see it and can write files to it but the new one can not see any of the others.
    something not turned on but what.
    when i try to map a network drive it gets as far as mshome then says that i don’t have permission.
    logged on as administrator ?
    what has this muppet done ?
    Chris Wool replied 18 years, 2 months ago 2 Members · 15 Replies
  • 15 Replies
  • Jason Xuereb
    28 October 2007 at 11:39
    Have you got a router?
    Has the new computer got the same workgroup name as the others?
    28 October 2007 at 11:45
    quote Jason Xuereb:
    router yes 2 all otherworking ok 5 computers 2 network printers.
    names i think all line up tried different cable and ip address all manually set.
    fire wall on this computer set to trusted the new one.
    its pelting with rain and cold here
  • Jason Xuereb
    28 October 2007 at 11:57
    Check your Ip address
    right click my network places
    goto properties
    right click lan connection
    goto status
    goto support tab
    it should be 192.168.0 something
    Leave the network adapter to obtain its ip address through DHCP
    make sure the lan calbe isn’t plugged into an uplink port on the router
    check the workgroup name by right click my computer
    going to properties and goto the computer name tab
    Verify this against your other computers.
    Also try and ping your gateway
    Goto start
    run
    type in CMD
    u get a prompt
    type in: ping 192.168.0.1 and paste your reply here
    28 October 2007 at 12:05
    quote :
    sent 4 received 0 lost 4 100% loss
  • Jason Xuereb
    28 October 2007 at 12:07
    Do you know the ip address of your router? Or another computer on the network?
    28 October 2007 at 12:15
    other computers
    192.168.0.10 pinged ok
    192.168.0.35 pinged ok
    192.168.0.85 pinged ok
    192.168.0.30 soljet pinged ok
    thanks for the time by the way
  • Jason Xuereb
    28 October 2007 at 12:20
    whats the current ip and subnet of the new machine?
    It’s ok its 11.20pm here in oz and im printing 10 metres of window perf.
    28 October 2007 at 12:28
    new one called robn 192.168.0.50 255.255.255.0
    file sharing on no firewall.
    i can access Robin from old computers and copy and paste files to it.
    but robin can not see any of the old computers although if i ping the old computers from robin it says ok no loss,
  • Jason Xuereb
    28 October 2007 at 12:30
    Can you make sure the workgroup name is the same?
    check what it is on another computer probably MSHOME and check it on your new computer?
    28 October 2007 at 12:39
    mshome on all
    xp pro by the way
    what i cant find is windows security centre in case there is something in there
  • Jason Xuereb
    28 October 2007 at 12:42
    Security centre in under the control panel
  • Jason Xuereb
    28 October 2007 at 12:47
    See this link:
    http://72.14.253.104/search?q=cache:pLG … =firefox-a
    Can’t See My Computer on the Network
    28 October 2007 at 13:00
    quote :
    should be but i cant find it.
    any way bed time for you aint it
  • Jason Xuereb
    28 October 2007 at 13:06
    You got zone alarm or something installed?
    Can you also try this
    Goto to one of your old computers that has a shared directory. Remember the shared directories name and get the ip address of that computer
    Then on your new computer
    Double click my computer
    and in the address put int
    \\ipaddress\sharefoldername
    What do you get?
    Bed time soon for me 12.05 now.
    28 October 2007 at 14:21
    thanks jason
    i think the system must be week cos it sprung in to life when i plugged just two computers together, then it slowly found the others.
    apart from the furthest away, only 30 ft atmost.
    thanks
