• Help Needed!!!
    Posted by Deleted User on 16 July 2007 at 14:04
    I am currently in process of doing a 26ft x 2ft lightbox for a customer, the customer would like a full colour sign to go onto the lightbox, what i normally do is get a full colour digital print onto clear adhesive vinyl (same size as acrylic) then just stick directly onto the acrylic and cut off the access acound the acrylic).
    however when i so this i have to cut in between were the sheets join and this normally causes light to show through when the lightbox is on.
    my customer stated he does not want any gaps or light to tshow through between the acrylic sheets were they join.
    Can anyone advise me on how to get around this? a mate of mine told me flexi sign cases with printed canvas is the answer but the thing is i have already ordered and received the lightbox however i have told my supplier to put the acrylic on hold for now.
    i was thinking of getting 3mm opal acrylic and 2mm clear and then sandwiching the print inbetween but i think the gaps on the clear might still show.
    can anyone help me out on this one?
    any help would be much appreciated.
    Phill Fenton replied 18 years, 5 months ago 8 Members · 21 Replies
  • 21 Replies
  • David Lowery
    16 July 2007 at 14:07
    I seem to remember that a conpany does clear plastic jointing clip so that the panels would not separate, If I remeber rightly it was SMP Metal Products, near Norwich (I think 😕 )
  • Deleted User
    Deleted User
    16 July 2007 at 14:24
    Basically i need to have the full colour image on the light box in 1 piece rather than cutting in so that there are no gaps for the light to show through.
    the actual problem i have is with light showing through the gaps of the print which has been cut were the sheets join
  • David Lowery
    16 July 2007 at 14:27
    FlexFace is your only answer to that one.
    See if your box supplier can do a retrofit to the box so it will take a flexface 😕
  • Deleted User
    Deleted User
    16 July 2007 at 14:30
    Yes i was advised that flexface would be best but the only thing is i have already got the lightbox now.
    is there any way ican use this lightbox? how is a retrofit fitted?
  • David Lowery
    16 July 2007 at 14:33
    You’ll have to ask your supplier if it’s possible. 🙄
    16 July 2007 at 17:02
    Who have you used as a supplier for the box and does this include the panels? If it does just tell them that you want the panels rebated as you should never rely on just two pieces of acrylic butted together at the edges. Lock the panels together with panel locks to prevent the moving apart.
  • Deleted User
    Deleted User
    16 July 2007 at 19:09
    quote martin:
    my supplier is a local plastic supplier company who also make their own boxes and supply.
    the panels arent the problem the problem is the clear printed vinyl that goes onto the panels but needs to be cut where the panels join, this then causes about 1-2mm light to show through where it has been cut.
    if only there was a supplier who could supply a 26ft x 2ft panel in 1 piece then i could stick on the digital printed vinyl in one go without having to cut but then i would have a problem getting the 26ft panel on site to go into the box.
    im sure people on this forum must have had this problem and know a way around it.
  • Glenn Sharp
    16 July 2007 at 19:16
    To be honest, I think you’ve already been given the answer.
    Flexface is the only way I know of getting a seamless face….I know you have already bought the box but I can’t see a way round it unless as Dave has said your supplier could adapt it
    i had this problem once… i.e. had lightbox and customer didnt want joins.
    i used a company called "redline" (i forget the right name) they sell lengths of banner tensioning framing. i basically rivetted the framing to the face of lightbox, printed the sign on back-lit banner and fitted like flexi… worked very well but was very tight to fit without the use of a hammer. (i say that because the redline framing requires the beading to be hammered into place) this proves difficult due to the bounce/flex on a 6inch return lightbox. 😕
    anyway, the job is still up and working spot on 2 years later… just thought ide mention it as an alternative.
  • Deleted User
    Deleted User
    23 July 2007 at 09:51
    I have been advised to have the signage printed onto backlit film and then just slide it into the lightbox infront of the opal acrylic.
    does this sound good enough?
  • Glenn Sharp
    23 July 2007 at 10:30
    I would say definitely not
    the wind would get behind it and rip it right out…it wouldn’t last 5 minutes
  • Deleted User
    Deleted User
    23 July 2007 at 10:36
    Well what if the backlit film was sandwiched between a 3mm opal arylic (behind the backlit film) and a 2mm clear arylic infront of the backlit film?
  • Glenn Sharp
    23 July 2007 at 11:44
    then you would be back to your original question….you would still have to have joins in the 2 mm 🙂
    23 July 2007 at 11:58
    Martin has already described the answer to this, perhaps you haven’t understood his answer – the panels need to be re-bated (routed – so that the edges are "stepped" this way when they are butted together one panel overlaps the other.
  • Deleted User
    Deleted User
    23 July 2007 at 13:10
    the panels come rebated as standard, the problem is not with the panel its with the printed vinyl were the 2 panels join. i would have to stick on the print over the panels then cut down the print were the panels join and this will show light through. I need the print to be in 1 whole peice so that i do not have to cut into it.
  • Glenn Sharp
    23 July 2007 at 13:24
    Ali
    I don’t think you will come up with a simple solution on this one…as has been said…the only way to achieve what you want is to go FlexFace
    I know you have already bought the box but Rob has given you a way round it
  • Andy Gorman
    23 July 2007 at 13:25
    Unless you can get a piece of Perspex at 26 feet long then I reckon flex-face is the only way. Dunno if you can retro fit it to another lightbox though. Even if you applied the print in one piece after the panels were in place, you’d still see some evidence of the joins in the panels. That’s a very picky customer you’ve got!
  • Deleted User
    Deleted User
    23 July 2007 at 13:37
    I know rob gave me a way around the problem but thats abit too advanced for me. i know i wont get a 100% way around it by using panels but will using the back lit film way give me a better result than using printed vinyl and cutting down were the panels are?
    i think if using the sandwich method using back lit will show less of the panels joining then i will go with that after all i did tell the customer that there will allways be something showing the joind in the panels
  • Russell Spencer
    23 July 2007 at 13:47
    I think insight used to do a retro-fit framing system for flex faces, it replaces the standard beading on a light box..wait one….
    yes here
    http://www.insightsignsystems.com/spectraspeedflex.htm
    bottom of page there is a ‘retrofit’ option
  • Deleted User
    Deleted User
    23 July 2007 at 14:00
    Thanks for that, at last i see some light at the end of the tunnel.
    I will give them a ring and see if they can help me out.
    23 July 2007 at 14:51
    Could you print the two halves separately allowing an extra 5mm or so overlap at either side of the join – then wrap this excess printed area into the rebate on each panel?
