Home Forums Sign Making Discussions Neon, LED, Lighting help making dibond trays please?
  • help making dibond trays please?
    Posted by Steve Underhill on 26 November 2007 at 18:12
    I cannot seem to find Richards tutorial about making dibond folded trays, I have searched the boards and drawn a blank, I especially would like to see the routing and corner finishing parts.
    Can anyone point me in the right direction?
    Steve Underhill replied 18 years ago 3 Members · 4 Replies
  • Harry Cleary
    26 November 2007 at 19:01
  • Steve Underhill
    26 November 2007 at 19:09
    I did see that one Harry thank you, I was under the impression there was another one that showed the router cutting of the grooves before you fold etc.
    I May be wrong, of course as I invariably am.
  • David Rogers
    26 November 2007 at 20:47
    The link Harry put up is more or less they way i do mine.
    There is a ‘fancy’ corner routing method to prevent the join being right on the edges, but to be honest – it’s fast, easy & effective to do it this way. And I’ve never seen an unsightly join.
    I use a 3/8" ‘1/2 Round’ router bit not a 90degree ‘V’ cutter as it allows for a degree of ‘overbending’ & a perfect gap for filling with ‘Evostik Serious Stuff’ before taping in place (sets beautifully in place overnight).
    For extra strength, a couple of short (2") bits of ‘L’ angle stuck in place provide an excellent support if the tray is not to be permanently fixed in place.
    If flood coating – I do it after routing, but before bending (so I don’t mark it, and no folding / wrapping round corners to bother about).
    It is though VERY important to get the depth JUST right. Not deep enough & you risk cracking the alloy / being hellishly hard to bend…to deep, well let’s just say you wont want to flex it too many times!
  • Steve Underhill
    26 November 2007 at 21:02
    Thanks David, most helpful, for now for my shop sign I was going to do it this way but instead am going with the sheet standing off the wall and corners rounded
    thanks again
