Home › Forums › Printing Discussions › General Printing Topics › Error Code 1A39 Epson Colorsure s80600, help needed.
Posted by Gary Husband on 10 November 2024 at 11:31Hi has anyone had the error code 1A39 on their epson colorsure s80600?
If so can you point me in the right direction please?Gary Husband replied 1 year, 1 month ago 4 Members · 4 Replies -
Hi Gary
I run HP latex, so I am not the best to advise.
But from what I can find online is that the “1A39” error code generally indicates an ink system issue and is often related to problems with the ink supply or ink flow.These are not my instructions, but should help.
Ink Cartridge Issue:
A cartridge may be empty, improperly installed, or not recognized.Ink Delivery System:
There might be an issue in the ink delivery system, such as a blockage or a failure in the pump that supplies ink from the cartridge to the printhead.Air in the Ink Line:
Air bubbles in the ink line can disrupt ink flow, causing this error code.Ink Pressure or Sensor Issue:
Sensors that detect ink flow may be malfunctioning or blocked.Try the following…
Power Cycle the Printer:
Turn off the printer, wait a few minutes, and then power it back on.Check Ink Cartridges:
Ensure all cartridges are seated correctly and are not empty.Inspect Ink Lines and Dampers:
Look for visible air bubbles in the ink lines or any obstructions.Run Ink Charge or Cleaning:
Use the printer’s menu to perform an ink charge or clean the ink system to help flush any blockages.Contact Support:
If the error persists, contact Epson support or a certified technician, as this could indicate a need for professional servicing. -
Looks like it might be a head error.
https://printcopy.infoEpson Colorsure s80600 – Error Codes
Code: 1A37
- Description: Thermistor error
- Causes: The head FFC is not connected correctly.
• A temperature out of a predetermined range was detected by the Head thermistor.
• Head thermistor failure - Remedy: Is the head FFC connected properly without being connected at an angle and any abnormalities such as a ripped terminal cover?
1. Replace the head FFC.
2. Replace the print head.
Code: 1A38
- Description: Transistor environmental temperature error
- Causes: Transistor failure
• A temperature out of a predetermined range was detected by the Head thermistor. - Remedy: Replace the print head.
Code: 1A39
- Description: Head error
- Causes: Connection failure of the head FFC.
• Electric parts or components are damaged due to improper head FFC connection such as connecting it at an angle.
• The drive circuit in the print head is damaged.
• The fuse of the main board has blown. - Remedy: Is the head FFC connected properly without being connected at an angle and are there any abnormalities such as a ripped terminal cover?
2. Replace the print head. (Since identification of the error caused between the print head (Full) and print head (Home) cannot be made, replace the print head one by one.)
3. Replace the main board.
Code: 1A3A
- Description: CR motor cooling fan lock error
- Causes: The CR motor cooling fan does not work.
- Remedy: Check if some foreign object prevents the fan from turning.
1. Remove the foreign object.
2. Replace the CR motor cooling fan.
Code: 1A3B
- Description: Mist collection fan lock error
- Causes: The mist collection fan does not work.
2. Replace the mist collection fan.
Code: 1A3E
- Description: PS cooling fan lock error
- Causes: The PS board cooling fan does not work.
2. Replace the PS board cooling fan.
Hi Gary, unfortunately it’s going to need a new head(s). I supply these and it’s always a print head I’m afraid with this error.
Just out of interest how much do you charge for the printheads and do you fit them? I know you need specialised software otherwise I’d do it myself.
