Home Forums Software Discussions Corel Software help/advice on fill in coreldraw problem
  • help/advice on fill in coreldraw problem
    Posted by Michael Dunn on 15 February 2008 at 22:00
    hi – could someone take a look at this file of a logo i am partway through and maybe explain where i am going wrong?
    i need to fill the two halves of the circle either side of the jagged line with red – but have lost the ability to do so.
    this has happened before.
    i have tried allsorts to rectify it,
    cheers.
    Michael Dunn replied 17 years, 10 months ago 7 Members · 9 Replies
  • 9 Replies
  • Ian Bingham
    15 February 2008 at 22:12
    Is it for printing or cutting?
    Ian
  • Ian Bingham
    15 February 2008 at 22:14
    you need to join the lines, they are broken apart
    ian
  • Harry Cleary
    15 February 2008 at 22:18
    If you use the Powerclip to fill the shape you will see a line running across the whole image….not sure how to solve that without redrawing it.
    15 February 2008 at 23:58
    i haven’t looked at the file, sorry, but from what you say, and the responses, i’m guessing you need to make 2 halves of a circle different colours / fills,
    if you’ve got a zig zag line across it, draw a box which has one line through the circle, convert to curves and add your nodes / zog zags on the line crossing the circle, select all, then intersect, remove the box, and you’ll have a new ‘half’ ontop of the circle, you can weld / trim to make two perfect halves, or just leave the half circle ontop of the whole circle.
    i hope that makes sense, sounds complicated, but would take just a minute or two.
    Hugh
  • David Sallis
    16 February 2008 at 00:13
    There you go
  • Michael Dunn
    16 February 2008 at 11:47
    thanks for the replies guys
    ian – it’s for printing and cutting, as he wants it on stationary and labels along with signs and banners
    harry – not sure about the powerclip function
    hugh – i’ll have a go at working through your description later- it sounds like it makes sense. i think what i have been doing wrong previous is for such as this – drawing a circle, manually inserting the lines, then using the shape tool to break apart – but – not joining the lines as ian noticed.
    although its prob not good practice – its only become a problem here as i needed to fill with colour to print from it as well as cut.
    daveyboy – perfect – thanks – i can get on with it while i suss out the proper techniques 😀
    16 February 2008 at 12:14
    i did have a pic of what to do but i cant post it here, so how did you attach files please ?
  • Nick Minall
    16 February 2008 at 12:21
    You cant do it here mate, may be this post has been move?
    Nick.
  • Michael Dunn
    16 February 2008 at 13:46
    you mean the file – not the pic?
    i had to post the corel file in another forum and ask the mod to move it here Chris
    if you could post yours where its allowed and link it it would be helpful – cheers
