Home Forums Printing Discussions General Printing Topics Hell with printing graphics on cling vinyl can anyone help
  • Hell with printing graphics on cling vinyl can anyone help
    Posted by ashminhas on 21 February 2005 at 23:59
    Hi there
    for the last few weeks i have been trying to make a sticker about 8″ X 5″ in size which is die cut to its own shape
    I need the sticker to be able to be reusable and residue free, hence i decided to use static cling.
    I also need to be able to print on this sticker in full photo quality and for it to have a part that is transparent in the middle of the graphic. that is transparent. The actual image doesn’t need to be reversed on the static cling as the sticker needs to face outwards (i.e not backed up by the glass)
    I then found out it is not possible to print such high res on static cling so then i decided to print onto vinyl and then overlay onto the static cling. Which then leaves the issue of having to cut the vinyl first so i have the transparent part in the middle before overlaying onto the static cling so u can see through the hole.
    However it is working out very labour intensive to actually manually take each sticker and overlay on static cling.
    Can anyone shed any light of an easier method????
    it would be much appreciated
    Ash
    Mark Shipley replied 20 years, 10 months ago 3 Members · 4 Replies
  • Mark Shipley
    22 February 2005 at 08:42
    Hi Ash,
    I’ve had very good results printing onto Hexis static cling both white and clear using a VersaCAMM.
    Not sure how you are trying to print them , please expand on the process you are using and maybe we’ll be able to help out!
    Mark
  • ashminhas
    22 February 2005 at 12:56
    Hi mark
    is it possible to have u’r email address so we can discuss further u are not based to far away from me, is it possible to get some advice from you. i am a complete newbie to sign making!
    Thanks a lot
    or u can mail me on
    ash_minhas@hotmail.com
  • Ian Higgins
    22 February 2005 at 13:02
    Mark,
    When you print on clear does the image look ok??
    I have tried it using the Cadet but not with much sucess.
    Ian
  • Mark Shipley
    22 February 2005 at 13:28
    Hello Ian,
    I have had really good results with printing with the VersaCAMM onto clear! The variable ink setting did puddle quite badly but the variable dry works a treat.
    I don’t know if this will help but here are the settings I found worked best for me, you may able to fiddle around and see if they work for the Cadet.
    Hexis micro2 profile (one way vision film)
    720×720 dpi
    Variable dry
    Overprint 1
    Pass count 16
    Head speed 500
    I used 35oC print and 45oC drying heat, I also have to use the long media clamps to stop the media ‘puckering’ at the sides.
    I hope this is of help.
    Mark
