have major oracle 651 problems help please?
Hi all
never used 651 before but have 2000 fleet numbers to make which equates to 80 mtrs of vinyl so thought i would use 651 instead of the normal 751c or more recently used 551 both of with are very good vinyls which i never have problems with.The problem with the 651 is that as soon as it was put into the cutter it cockled up and curled. I’ve tried it on my Summa D60 and my 120SE it happens on both, the problem is that as the vinyl is cockled it rucks up beteen the rollers as it moves backwards and forwards eventually raising enough to cause the knife to strike causing an axis error. Cut runs are only 1.5mtrs long never had this problem before with any other brand of vinyl & i can load 751c into the cutter and cut the file with no problems.
Needless to say i will be on the phone to Europoint in the morning for them to pick it up and exchange it for a better quality vinyl. All of my vinyl is stored the same and i have left the vinyl to climatise since having it delivered on Thursday.
Would be interested in your views experiences with this vinyl or similar problems with other vinyl brandsKev
