Home Forums Vinyl Cutter Discussions Graphtec Vinyl Cutters Graphtec Cutter throwing a wobbly – Any ideas
  • Graphtec Cutter throwing a wobbly – Any ideas
    Posted by David Hammond on 21 September 2016 at 12:32
    Had a media jam earlier cutting some laminated print, freed the jam, and tried again but the test cut is terrible.
    Changed the blade – Same result
    Tried tangential modes – Same Result
    Messed with the offset – Same Result
    The test cut scores OK when lower pressure, but when increased to cut through the print properly it throws a wobbly and doesn’t cut a clean test cut.
    Any suggestions?
    David Hammond replied 9 years, 3 months ago 1 Member · 1 Reply
  • 1 Reply
    21 September 2016 at 13:07
    Spoken to Graphtec who were very helpful, and instantly knew the problem.
    Removed the top cover, and loosened the screws holding the top bearings in place, then tightened back up, still a little play in the carriage but a fraction of what we did have. :thumbsup:
