Home Forums Vinyl Cutter Discussions Graphtec Vinyl Cutters Graphtec CE6000-60 cutting the wrong sizes
  • Graphtec CE6000-60 cutting the wrong sizes
    Posted by Alan Brown on 26 April 2015 at 09:03
    Hello everyone,
    Just upgraded to a brand new CE6000-60, and it’s working just fine for the most part! I’m using it with Flexisign 8.1, but I seem to be having a problem with the sizing. It seems to be scaling the designs up in size by around 10%, so for example I send a 10x10cm square but it will actually cut 11x11cm
    I don’t suppose anyone is aware of some setting or configuration I have missed or something?
    Many thanks,
    Alan
    Ewan Chrystal replied 10 years, 8 months ago 3 Members · 4 Replies
  • Gil Johnson
    26 April 2015 at 11:21
    Hi Alan,
    Obvious first – have you checked the sizing scale on production manager? on flexi the size can be altered from here, it should be set to 100%.
    Gil
  • Alan Brown
    27 April 2015 at 06:14
    Hi Gil,
    Thank you for the reply.
    The cutting manager is set to 100%, in fact the settings in flex are pretty much the defaults – some tiny 1mm borders and that’s it.
    I’ve gone through about 10 meters of stock trying different settings to get this sorted and it’s getting quite annoying now! I can pretty much guess how much I need to scale my designs down by, but still, I like things to be precise!
    Many thanks,
    Alan
  • Gil Johnson
    27 April 2015 at 07:07
    I remember having a similar problem years ago when running flexi for mac, can’t remember how we sorted it though! (think it was something to do with the cables / ports).
    Did you buy flexi through an agent? – if so would be advisable to contact them.
    Gil
  • Ewan Chrystal
    27 April 2015 at 08:40
    I’d give Granthams a call. They’ve always been able to sort any tech problems i’ve had over the phone
