Home Forums Vinyl Cutter Discussions Graphtec Vinyl Cutters Graphtec-CE5000-60 HP360 Latex and ONYX RIP/CUT Server
  • Graphtec-CE5000-60 HP360 Latex and ONYX RIP/CUT Server
    Posted by Mike Wilkinson on 7 October 2019 at 12:25
    Can anyone advise me on setting up a print / cut file. I’ve just bought a secondhand Graphtec CE5000-60 and I’m using a HP360 Latex and ONYX RIP.
    I’ve printed the document and named the cut path as ‘CutContour’ using a spot colour in illustrator and the ONYX RIP recognises the cut paths but when I load the material and set the optical eye over one of the registration marks, I get ‘MarkScan Error’ message on the Graphtec after I clicked Cut Path in ONYX. If I then press enter on the cutter, it starts cutting the paths at around 500% larger than what it should be. :bangshead:
    Help!!!!
    Mike
    Robert Lambie replied 6 years, 2 months ago 1 Member · 1 Reply
  • 1 Reply
    10 October 2019 at 06:52
    I do not use Illustrator for this type of thing, it would be done in Signlab, but the same principle.
    could the issue not be your sizing within Illustrator as I know it has limits to its sizes.
    In Signlab it’s very straight forward. apply the contour cut and export as a PDF. etc. etc…
