Home Forums Vinyl Cutter Discussions Graphtec Vinyl Cutters Graphtec CE5000-120 centres out of registration
  • Graphtec CE5000-120 centres out of registration
    Posted by Colin Bland on 1 October 2009 at 23:13
    I have a CE5000-120 been brilliant use it all day every day.
    The problem I have is the way it cuts the centers on Large runs of text.
    The machine goes through and cuts the centers of the letters ie centers of O etc then comes back to the beginning and cuts the outside shapes.
    It will do this accurately centers about 2m for about 10 lines of text over that the centers to outside registration is poor.
    Is it my software (i cut directly from corel through the cutting master program) is there something I’m doing wrong? I have the cutting master set to restrict media movement etc any advice much appreciated
    Colin
    Colin Bland replied 16 years, 3 months ago 3 Members · 5 Replies
  • Neil English
    2 October 2009 at 12:52
    Maybe try speed priority?
    2 October 2009 at 13:59
    if optimize is set to none and it still does it then the drawing letters have probably been broken apart.
    corel will cut from the back of the layer to the front.
  • Colin Bland
    2 October 2009 at 14:24
    Cheers Neil I will look at that
    Chris so if I regroup the letters you think that may solve the problem?
    Colin
    2 October 2009 at 14:36
    if they are broken apart group or combine may help but retyping the line will cure it.
  • Colin Bland
    2 October 2009 at 16:32
    Hi Chris tried all that and still didnt work so reset all the settings in Cutting master and found that the restrict media movement is now working properly – had that setting before but just wasnt doing it – must have lost its way
    Thanks for suggestions
    Colin
