Home Forums Vinyl Cutter Discussions Graphtec Vinyl Cutters Graphtec CE 5000-120 Origin Point
  • Graphtec CE 5000-120 Origin Point
    Posted by Jack O'Loughlin. on 1 October 2009 at 17:15
    Hello I hope you can help!
    My Graphtec does not leave enough material in preparation for next job. It simply pulls the material back to where it considers correct but the n when it initiates the next job the blade runs off the material front end. What setting must I adjust to tell the machine to allow for this.
    JackO
    Jack O'Loughlin. replied 16 years, 3 months ago 4 Members · 9 Replies
  • 9 Replies
    1 October 2009 at 17:24
    Jack you should have a button where you can set the origin on mine it at the bottom right corner of the control panel.
  • Jack O'Loughlin.
    1 October 2009 at 17:36
    eh! Thanks Lynn I know that but it makes no difference. I have to run off 40-50 mm of material and reset origin between every single job.
  • Liam Pattison
    1 October 2009 at 17:50
    In your cutting software, have a look around there may be an option to set what the blade does after a job. I know there is in mine but i don’t bother with it, as i always reset material after every cutting job. Maybe a bit long winded but it works for me.
    Liam
    1 October 2009 at 18:14
    yes Jack you do have to as the plotter only remembers the first point it measures.
    1 October 2009 at 18:15
    quote Jack O’Loughlin:
    check in the plotter menu for advance after job normally set to 10mm.
  • Liam Pattison
    1 October 2009 at 18:22
    Hi Chris,
    Just me not quite understanding, do you alter that ‘advance after job’ on the cutter itself or on the software on the computer?
    Cheers Liam
    1 October 2009 at 18:28
    plotter menu
    but some programs do have the facility.
  • Liam Pattison
    1 October 2009 at 18:34
    Thanks Chris,
    had seen the option in my old cutting software, but couldn’t remember seeing it in the one i use now.
    Liam
  • Jack O'Loughlin.
    2 October 2009 at 08:06
    Thanks lads,
    I cannot be certain but it appears that it goes through some measuring moves in both and y axes once new material is loaded so it should have the facility to adjust this ‘slack’ material.
    JackO
