Home Forums Vinyl Cutter Discussions Graphtec Vinyl Cutters Graphtec 3000 Mk2 Cutting Master Illustrator problem
  • Graphtec 3000 Mk2 Cutting Master Illustrator problem
    Posted by Russell Pavey on 6 June 2006 at 13:44
    I’ve been using this combo for a while now without hitch but I’m now trying to do a slightly longer sign than usual (45 x 180cm) and when I go to set the output settings in Cutting Master and change the Valid area to slightly larger that the document it will allow me to change the X axis ok but the Y axis won’t – it pops up with an Illustrator error message saying "Value must be between 20 & 1514"
    I have checked the page length on the plotter and this is the default 5000mm.
    Anybody any ideas on this.
    Many thanks
    Russ
    Russell Pavey replied 19 years, 7 months ago 2 Members · 2 Replies
  • Jayne Marsh
    6 June 2006 at 20:11
    From what I understand the X axis is the roll length and the Y axis is the left to right of the plotter, so you would need to set the X axis to the 180cm that you need. Try that and see if it works
  • Russell Pavey
    7 June 2006 at 13:57
    Thanks for that Jayne.
    It was that but the preview in the cutting master threw me a bit as it was the other way round to what I usually get (if you understand me)
    Thanks again
    Russell
