Home Forums Sign Making Discussions General Sign Topics Gluing Wood To Acrylic – recommendations on adhesives please
  • Gluing Wood To Acrylic – recommendations on adhesives please
    Posted by Unknown Member on 25 November 2014 at 14:21
    Guys,
    I’ve got a wonderful job on for a well known Auction house in London.
    I need to glue 18mm thick block of 400mm x 400mm CNC cut MDF to a 10mm thick sheet of perspex.
    We will then hang the perspex sheet on the wall.
    Need to have a solid bond between the two material.
    any recommendations on adhesives?
    Kevin Flowers replied 11 years, 1 month ago 2 Members · 2 Replies
  • John Harding
    25 November 2014 at 15:12
    assuming the wood is to the face can you not drill and screw from behind? failing that gorrilla glue or VHB?
    john 😀
  • Kevin Flowers
    25 November 2014 at 16:32
    James
    i normally use SIMSON ISR 70-03 its a sealer adhesive allows for movement between different types of materials as you have.Robert Horne stock use the primer as well and it will hold an elephant up. I put an exterior sign up over 10 years ago with it and still in place today.
    http://www.bostik.co.nz/productDetails. … &c=115&t=i
    P.S James give me a PM need to know if you got a file i sent you.
