Home Forums Printing Discussions Mimaki Printers Ghosting on printing Mimaki CVj30 -130
  • Ghosting on printing Mimaki CVj30 -130
    Posted by Dave Holland on 1 May 2017 at 21:58
    Hi, Started printing this morning as usual and noticed that the Cyan and Magenta appear to be out of line and causing some ghosting around the edges. Cleaned, checked Drop setting and alignment, print test perfect.
    Please help!!!
    Stafford Cox replied 8 years, 7 months ago 4 Members · 9 Replies
  • 9 Replies
  • Paul Wile
    1 May 2017 at 22:39
    I had this exact problem. Are you using Raster link? I found out I was using the software incorrectly. When you are in print condition selecting es3 ink, media and resolution combination is only correct if all three blocks turn blue.
  • Dave Holland
    2 May 2017 at 10:55
    Hi Yes, Latest version of Rasterlink, was working fine and then the games began. What did you do to resolve the issue?. Many Thanks
  • Alex Waite
    2 May 2017 at 13:38
    Have you tried printing something else? could be a corupt file.
  • Paul Wile
    2 May 2017 at 18:29
    When I had this problem I was using the software incorrectly.
    Make sure that when you pick your ink set, media and resolution that the 3 bars all stay blue. If they don’t all stay blue then your options aren’t correct and won’t print correctly.
    Try picking a different media etc in your software until all the blocks turn and stay blue.
  • Stafford Cox
    3 May 2017 at 14:45
    Have you tried cleaning the encoder strip?
  • Dave Holland
    4 May 2017 at 07:29
    Hi Stafford, Yes. cleaned the strip, printing fine on all other colours just Cyan all misty!. Hybrid think it could be electrical issue to the head?. Higher res lessens overspray and only one side as suspected when printing UNI . Not changed anything from when it was working fine. Driving me nuts as out of operation printing wise until next Wednesday.
  • Stafford Cox
    4 May 2017 at 08:20
    Yeah, it definitely could be the head. Although I would want to eliminate everything else first of course. Usually an electrical fault shows itself on only one resolution (i.e. 540×1080 but not 720×1440) but not always. Have you got someone booked in to look at it?
  • Dave Holland
    4 May 2017 at 11:46
    Hybrid still to confirm but open to suggestions if quicker!. I’m in Fife
  • Stafford Cox
    4 May 2017 at 18:07
    My closest guy is about 4 hours away but could probably do early next week if that helps?
