Home Forums Printing Discussions Printer Ink getting ink down the line?
  • getting ink down the line?
    Posted by John McNickle on 5 April 2012 at 16:59
    hi my valuejet was printing while i was away, there seems to be a problem with my bulk ink yellow, it had ink in the top tank but wasnt dripping into the lower so it had ran out, i sorted this problem but i cant get yellow down the tube to the head?? ive put it thru strong flushes and tried printing solid yellow to forse it to suck thru but no joy yet 🙁 anyone able to help me on this one?
    thanks in advance
    John McNickle replied 13 years, 5 months ago 3 Members · 5 Replies
  • Stafford Cox
    18 April 2012 at 10:13
    Best bet would be to get a syringe and pull it through gently from the damper. Once you’ve got rid of the air, put the damper back on the head and run a clean and it should all flow nicely again.
    Let us know if you get stuck.
    Stafford
  • John McNickle
    18 April 2012 at 13:14
    Cheers stafford, i did that 🙂 i googled the problem and found a guy asking the same question, someone told him what to do so i did a bit of open heart surgery to it, gave all the dampers etc a good cleaning and anything that needed it so its back to life 🙂
  • Stafford Cox
    18 April 2012 at 14:28
    Excellent! Job well done 😉
    18 April 2012 at 23:33
    John, for future reference should something like this happen again. It’s a good idea to change the small "O" seal if you disturb the dampers. Read a few times on forums that people had problems with air ingress after replacing the dampers & not changing them.
  • John McNickle
    19 April 2012 at 10:01
    yes Martin i read that myself and checked the o ring out while i was in there, so i know where it is etc 🙂 thanks
